Subwoofer Installation
Old Jul 30, 2009 | 03:35 PM
ghstrider87's Avatar
I am going to be putting in a single 10" subwoofer in my 2003 quad cab in the next few weeks and am looking for some pointers on where to run the wires both from the head unit and battery to amp. i have the wires hooked up to the battery and head unit now i just need to run them.
Old Jul 30, 2009 | 10:33 PM
rip 112's Avatar
If you mount the amp under the driver seat you can easily pull up the carpet there and run the wire through. Its easy to pull the plastic step plate. You will also have solid metal for a good ground there.
Old Jul 31, 2009 | 08:47 PM
sctsnpr's Avatar
Make sure you run the power turn on lead from the head unit and rca cables far from the power wire.
Old Aug 17, 2009 | 02:01 PM
alMout's Avatar
For the head unit, you can remove the driver side threashold door trim the the kick panel and run them there. For power, there is a rubber grommet in the firewall behind the brake pedal or you can follow the antenna cable to get in.
jay_d
Feb 20, 2010 06:23 PM
MNorby
36
Jan 19, 2005 06:41 AM
5125sc
Nov 17, 2004 09:22 PM
chucktownsend5
13
Oct 31, 2004 09:57 AM
rshelton88
29
Jul 22, 2003 02:40 PM
