Stiff, noisy windshield wipers
Old Feb 11, 2005 | 06:46 PM
NJMurvin's Avatar
Anyone else have noisy, stiff WWs?
Mine squeek and bounce like crazy - almost as if the rubber had hardened. But, it did this since it was new.
Has anyone changed theirs? Can you recommend a good replacement?
Old Feb 11, 2005 | 08:07 PM
Hemi Cat's Avatar
Yup, the rubber is hard. Replace them.
Old Feb 11, 2005 | 08:20 PM
gatf4's Avatar
Bosch are very good.
Old Feb 11, 2005 | 09:53 PM
MonkeyLips's Avatar
Rain X on the windshield help elminate that dang wiper blade chatter.
Old Feb 11, 2005 | 10:18 PM
Texcowboy9's Avatar
I change mine about every 6 months with Bosch on both my CTD and the wife's Mustang.
Old Feb 11, 2005 | 10:41 PM
torquefan's Avatar
There are some direct-fit replacements out there which mount more securely than the universal ones that rely on those cheesy plastic adapters to fit many different arms.
Old Feb 12, 2005 | 04:54 AM
JohnnyH's Avatar
I replaced with Anco replacement blades. The OEM drivers side would always chatter and bounce on the windshield. These helped initally, but are starting to do it ever so slightly. I use RainX windshield waher fluid and that helps a bit.
Old Feb 12, 2005 | 12:25 PM
gatf4's Avatar
Clean the windshield with Wax and Grease Remover (auto parts store body shop supplies) or rubbing alcohol 3 times then with windex and put new wipers on. You will be impressed.
Old Feb 12, 2005 | 12:52 PM
BDude555's Avatar
Bosch make a great, but costly wiper that I've been happy with.
Wipe down the windshield with comet, bon amy, what ever brand bathroom cleaner you might choose (trick done in detail shops to clean windows)
Old Feb 12, 2005 | 01:03 PM
Lightman's Avatar
I had the same problem after a while, and actually got the mopar replacements from the dealer - they were very cheap. Anyway they work perfectly and no more noise.
Old Feb 12, 2005 | 03:31 PM
Dodgezilla's Avatar
I had the same problem and it was completely cured with the Bosch replacements. Ah!! No more embarrassment when I turn on the wipers.....
Old Feb 14, 2005 | 01:31 PM
bhoeffner's Avatar
I have the Bosch replacements and still have the chatter when it is cold out. Cold here in Texas is 20's and 30's. Wish I could find a solutions to fix this.
Old Feb 14, 2005 | 03:02 PM
Peterbilt's Avatar
I just bought new wipers from the dealer. You get the wiper and arm assembly. I paid $15 for both and they are warrantied for a year. So, if the rubber gets hard just take them to the dealer.
Pete
Old Feb 15, 2005 | 01:28 PM
Jonesey's Avatar
Pete
Are you sure you don't mean the blade assembly. The arm assembly is the part with the large spring that the blade attaches to. Mine had an arm assembly with a weak spring that would lift at freeway speeds. I purchased just the arm assembly with no blade and it cost me appx. $22.00. I could have had it replaced under warranty but once again the local dealer insisted that I make an appointment for them to screw something up. No thanks here's your $22.00 and have a nice day.
Old Feb 15, 2005 | 03:52 PM
t-15 firefighter's Avatar
DTR's Self Appointed Beer Advisor
rain-X... that's all i use.
nuff said!
britt
