Steering Issues with 37" Tire
First of all I understand that when you start changing EOM with aftermarket parts you might run into some problems. With this in mind has anyone having steering issue turning a 37" tire when not moving? My steering hates turning while not moving and it does not want to move. I know I should be moving little to help the steering but man sometimes I have to turn the wheel while not moving especially when trying to maneuver a not so little Mega Cab into a parking spot designed for a Prius. The steering box/pump combo looks beefy enough that should be able to move the 37" tire easily. Heck my Land Cruiser (powered by a Hino 1HDFT Turbo Diesel) with the same size tire turns while stopped without any issues.
I've never had....wait... hasn't happen YET in the 3+ years i've had 37's on my truck. But i have gone through 4 steering boxes....
As far as the parking lot for compact cars thing.... I park as far back at the end of the row as i can, and usually take 2 spots so that no one parks next to me. Saves on door dings, and gives me more room to manuver incase i have to back out.
Maybe I need one of those hydraulic steering assist actuators. Anyone have on installed on their truck?
I have an AGR pump (the ram is sitting on my bench) on my chevy truck (1977) with 44's and sitting still you can turn the tires with 1 finger...and it's not even cross over steering, its got huge drop pitman arm....
So if they make one, seems like it would be a good upgrade for our trucks to get a better pump..
I have the same problem with my steering and it has stock tires on it, the pump and/or box also wine a little.
I always roll ever-so-slightly when turning...there`s a lot of weight over the nose of these trucks..much more than a Land Cruiser , if I had to guess
I`ve never had an issue with my steering in the 4+ years I`ve been running 37s
Although my Land Cruiser also has an inline 6 Turbo Diesel I am sure it is at least 300-400 lbs lighter than our CTD.
So you can turn your wheel sitting still and you don't feel any stiffness on the steering wheel and the pump growling a little? Maybe I need an upgraded pump TX_Diesel is talking about.
roughstock
Nov 2, 2013 01:48 PM
PEAKSTRYDE
Oct 11, 2007 04:20 PM
VikingDiesel
47
May 11, 2007 12:52 AM
