Steering gear box torque spec's
Hey all,
Im putting on a Red Head steering box this weekend.
Does anyone out there know the torque spec's for the frame mounting bolts and the pinch bolt on the the bottom of the steering column? Any other do's or dont's would be great.
From my 2005 manual:
TORQUE SPECIFICATIONS
DESCRIPTION....................................... ...... N·m........Ft. Lbs........In. Lbs.
Power Steering Pressure Switch......................10...........—........ .......80
Power Steering Line Pressure Line....................32...........23........... ....—
Power Steering Line Return Line HD..................51...........38............... —
Power Steering Line Return Line LD...................70...........52.............. .—
Power Steering Line Pressure Line To Pump........37...........27...............—
Power Steering Pump Mounting Bolts.................28...........27............. ..—
Power Steering Pump Reservoir Bolts.................13...........10............. .120
Power Steering Pump Bracket Bolts....................5............5........... .... 62
4X4 HD
1. Install the coupler (2) to the steering gear (3).
2. Install the coupler (3) to the intermediate shaft (2).
NOTE: New pinch bolts must be used for reinstallation.
3. Install the lower pinch bolt (3) and tighten to 28 N·m (250 in. lbs.).
4. Install the upper pinch bolt (1) and tighten to 57 N·m (42 ft. lbs.).
4X4 HD
INSTALLATION
1. Position the steering gear (1) the frame rail and
install the three mounting bolts (2). Tighten the
mounting bolts to 196 N·m (145 ft. lbs.).
2. Align steering coupler (1) on gear shaft (2). Install
pinch bolt and tighten to 49 N·m (36 ft. lbs.) torque.
unioncreek
Jun 29, 2005 02:00 PM
1stGenBikeHauler
Jan 25, 2003 12:31 PM
