Steering Brace
Old May 1, 2009 | 12:12 PM
checkster's Avatar
Originally Posted by Ace
I believe the Defiant is tops from every standpoint - engineering, installation and cosmetic. The steering flex it is designed to address is in the horizontal axis, so strengthwise it is actually stronger across that axis from an engineering perspective, being much thicker than the box tube stock. And as mentioned, it is a cleaner, better looking install.
THE PROBLEM IS THE BRACE HAS A DOG LEG IN IT, SO IT ISNT FLAT. ALL THE FLEXING IS AT THE BEND
Old May 1, 2009 | 12:18 PM
Ace's Avatar
Ace
It's a brace - not a billet shaft. You guys are over-thinking this.
Old May 1, 2009 | 12:32 PM
Clane's Avatar
The little thingy in your avator spins....
Old May 1, 2009 | 01:08 PM
checkster's Avatar
yeah i know.....but if it flexes just as much after you put the brace on its really not bracing anything.
Old May 1, 2009 | 01:17 PM
Ace's Avatar
Ace
It all adds up. Strengthwise, that is.
Old May 1, 2009 | 03:23 PM
enafzige's Avatar
Lol! Just noticed this...pretty neat Ace!
--Eric
Old May 1, 2009 | 04:09 PM
Ace's Avatar
Ace
That avatar's been around the Internet on many different forums for many years with many different users.
Old May 1, 2009 | 06:00 PM
Dan_K's Avatar
O.K. a little change in subject.
Put the brace on at noon, took all of 20 minutes. I loosened the 4 bolts holding the track bar in place, let my hand off of it and it stayed in place. I thought it was secure so I looked down at the directions, and WHAP, that SOB swung down and clocked me in the back of the head.
The dodge dealer put the updated steering on my truck, and a new steering gearbox, and didn't torque the bolt holding the pitman arm (supposed to be 180 ft/lb, and was maybe 30 ft/lb).
Very easy install all things aside.
Took her for a drive, and not a huge difference, but definatly less correction needed. I hate driving down a mild grade at 55 mph, and having to slow the truck down for a stoplight, this seems to be the time that it wanders the most. I saw a nice improvement under these circumstances.
Old May 9, 2009 | 06:50 PM
BroncoAZ's Avatar
I'm in the market for a brace as well. I tend to do a fair amount of turning the wheels while the truck is stationary while parking. Does anyone here know where I can just buy the stationary bearing and shaft adapter? I have mad welding skills and would rather make my own brace.
Old May 9, 2009 | 08:52 PM
Fisherguy's Avatar
Bud my B-D brace on last week, it's one of the few that will go one with KORE sway bar spacers.
The hole the steering box shaft goes through is off center but I was still able (barely) to get the bolts through and everything worked out.
I called them to tell them, they said they new about the problem but they checked all their stock to make sure they would all work...
Old May 9, 2009 | 09:38 PM
CD in NM's Avatar
I have the Defiant brace. It does what it says it will - add support to the steering box. It was an easy install, went right in without problems. I also have the shield that Defiant offers.
CD
Old May 9, 2009 | 11:00 PM
Danderson's Avatar
CD
Same here. So far,so good. Somebody needs to devise a rockshield for the square tubing braces. It's a fragile environment under there.
Old May 10, 2009 | 03:39 AM
Clane's Avatar
So after a little research, I've seen that there are 3 choices for a steering brace.
Defiant, Solid Steel, Bd.
Am I missing anybody else, and who has the best price on these?
thanks
DT Pro Fab also makes one. Just found it today while looking for a light bar.175.00
http://www.dtprofab.com/DT_DODGE%201.htm
Old May 12, 2009 | 12:43 PM
BMH95's Avatar
I've got the PSC version. It was very noticable to me, once installed. I think it cures the skipping and looseness in the front end, when you hit bumps in a turn. It just makes the whole front of the truck feel more stable.
It's the same mod we where doing on the 3rd gen Camaros decades ago. Helps stabilize things up front, in areas where there is a lot of force. It's not meant to be a frame member, rather just to stiffen things up.
Old May 12, 2009 | 01:18 PM
PRO-NRA's Avatar
I tried to install my PSC kit but the sector nut will not thread into the steering box. Looks like the new sector nut is a metric and the steering box is fraction. I called PSC and they claimed it is fraction but said they will send me a new one. I'm excited to install it.
