sirus antenna sucks
Old Jul 9, 2007 | 08:38 AM
FourX4Fabber's Avatar
sirus antenna sucks
Anybody have problems with the stock sirus antenna. Mine seems to lose signal alot, even driving down the open highway on a clear day. I have a cheaper sirus setup in my wifes suburban and it almost never loses signal unless you park under a gas staion overhang or under a bridge.
... seems to happen most often during a good song or during what could have been a really funny joke on the comedy stations.
thanks - Kurt
Old Jul 9, 2007 | 08:42 AM
soulezoo's Avatar
DTR 1st Sergeant
I feel your pain...
I have the aftermarket Sirius and I have the same problems you describe. I got it for a present and geez... I thought it was supposed to be better than regular radio... not really.
Old Jul 9, 2007 | 09:32 AM
GMScott's Avatar
thanks - Kurt
Same here!! In my 04.5 I used to have a little XM Roadie that would lose the signal more than the Sirius does though.
Old Jul 9, 2007 | 09:37 AM
Arkapigdiesel's Avatar
For whatever reason, the antenna that's put on these trucks are not worth a flip.
I wound up putting an aftermarket head unit in and using the Sirius Starmate as my Sirius receiver. I haven't had a problem since....
Old Jul 9, 2007 | 11:42 AM
Foxborough's Avatar
I would have someone check your connections. My antenna works fine for me, occasionally misses when passing under a bridge or lots of trees. It even picks up a signal when parked in my garage. I have had it miss when out in the open once or twice but found out later there was a lot of solar (sun spot) activity at the time.
Old Jul 9, 2007 | 12:43 PM
ssandlin's Avatar
No problems with my reception
Old Jul 9, 2007 | 01:24 PM
Hikecol7's Avatar
No problems
Actually the reception has been great. I have lost it a few times when I go under and overpass but the antennae even works with the slide-in camper over it. I would ask the dealership.
Old Jul 10, 2007 | 11:06 AM
Thanks guys, just checking before I go to the dealer. Guess I'll bug Brad on the way home.
Old Jul 10, 2007 | 10:07 PM
phloop's Avatar
Sounds like you need the wiring checked out. I had a Sportser replay that had the same reception as the Sirius in my truck. I have an SL100 now and the reception is better than the replay or the dodge radio. Seems like the sampling rate is getting better.
Old Jul 11, 2007 | 09:57 AM
MOJO1's Avatar
No problems with my reception.Sorry to here about yours sounds like they could track it down or replace it.I live in the country shade trees everywhere.
Old Jul 11, 2007 | 06:41 PM
nobull60's Avatar
I too have an after-market setup with no issues. Except for the water leak in the cab from my stupidity it works fine, and no more water issues. Silicone in the third light sure worked well !!!
Old Jul 13, 2007 | 10:28 AM
yellowhemi's Avatar
Mine sucks too.
Old Sep 10, 2007 | 02:21 PM
herb's Avatar
i JUST BOUGHT A CAMPER I AM PICKING UP THE END OF THE WEEK . THE OVERHANG OVER THE CAB IS GOING TO COVER THE SIRUS ANTENNA--ANYONE BEEN HERE DONE THAT YET ? WHERE DID YOU MOVE THE ANTENNA TOO ?
Old Sep 10, 2007 | 02:24 PM
Truckman0097's Avatar
Mine is not good
thanks - Kurt
It works fine most of the time, but if I go under an overpass or through really dense tree lined road - it cuts out - that shouldnt happen. I understand if I was going through a tunnel, but an overpass?? All 50 feet of it..should not make the radio cut out....
Old Sep 10, 2007 | 02:48 PM
2rowdy's Avatar
I stupidly paid the dealer to upgrade my code ref radio to sirius since I was already a subscriber, back on track now, my reception is alot better with the factory setup than with sirius sportster i had in my 04. I just miss the read out of artist and track. So if anybody has a code raq radio I'm, in the market.
