shut door then engine stopped
Old Nov 27, 2006 | 01:03 AM
mate's Avatar
have stock 03 2500 quad cab 4x4 Laramie
slamed passenger door engine stopped (started but would not run)
next day diesel started but when closed driver door engine quit.
now diesel will crank but won't start - get P0629 code(high voltage detected on fuel lift pump).
If I clear code will it start??? - will I fry ecm???
any ideas???
Help
Old Nov 27, 2006 | 05:19 AM
Hounddog's Avatar
Think I'd check main bulk head connectors,battery cables first.Make sure there tight.Then go from there.Pray if its towed in it stays not running!
Old Nov 27, 2006 | 09:19 PM
mate's Avatar
P0629 fuel lift pump circuit high OR fuel pump relay circuit high
what if I reset fault ? will it start then ? will loosing a ground make it go high?is there a hot wire touching the above?
Old Nov 27, 2006 | 11:48 PM
J BODY's Avatar
weird coincedense. I would say your canister mounted lift pump has failed. If you bump the starter you should be able to hear it run for 20 seconds. If it doesn't you can sometimes "tap" (beat) on it with a hammer enough to start running. If you can get it to "buzz" often the engine will start.
Old Nov 29, 2006 | 06:57 PM
mate's Avatar
when I turn ignition on but dont start I can hear lift pump for about 7 seconds or so - any ideas?
tfdcruiser
Apr 12, 2020 01:26 PM
Diesel-Dan
20
Sep 22, 2019 09:34 PM
robinlh
Aug 5, 2008 02:21 PM
Desert Diesel
Jul 31, 2007 07:13 PM
guyssets
Apr 27, 2005 12:53 AM
