seatbelt dinger
Old May 15, 2006 | 02:07 PM
Mallard's Avatar
seatbelt dinger
Is there anyway to disable the seatbelt dinger ? (without putting on your seatbelt or buying a clip from the bone yard)
Old May 15, 2006 | 02:15 PM
jennis2613's Avatar
I took the male center seat belt and clipped it into the drivers seat female.
Old May 15, 2006 | 02:21 PM
PEAKSTRYDE's Avatar
Read the manual, there is a psge that explains how to shut it off, I did on my 04.5
THAT THING SUCKS
Old May 15, 2006 | 02:53 PM
moterhead's Avatar
THAT THING SUCKS
He means the owner's manual, not the shop manual. It's a bit of an involved process, but actually does work. I found it easier to do with two people. Involves turning the ignition on & off & plugging in & unplugging the seat belt a certain number of times. Whatever number it says, do it more. Some posters on this topic have said it doesn't work with the min number, but does if more.
Old May 15, 2006 | 03:25 PM
4x4dually's Avatar
I just took the plug loose under the seat and put a wire from one side to the other. It has worked for years. I hadn't heard about the owners manual thing. I guess I might look into that.
JWB
Old May 16, 2006 | 08:32 AM
djja918's Avatar
Read the owners manual it explains how to shut it off, it is very simple and can be done is a matter of seconds you can also turn off the horn chirp when using the keyless remote to lock the doors. I did both on my 06. Dave
Old May 16, 2006 | 09:43 AM
rsailors's Avatar
dealer can turn off chime, but light will stay on with scan tool, generally only takes a few minutes.
Old May 16, 2006 | 10:12 AM
JD Dearden's Avatar
The new bully dog programmer allows you to disable it.
Old May 16, 2006 | 11:35 AM
BlackSheep5's Avatar
i just did what it said in the owners manual and it took about 30 sec by myself. it does not ding anymore but the seatbelt light stays on when ever you dont have it buckled.
joshshamblin66
14
Sep 8, 2010 10:34 PM
hot tempered
Dec 28, 2008 07:40 PM
afacey
14
Oct 8, 2005 12:26 PM
boarbuster
Nov 20, 2004 09:50 PM
jt
Mar 15, 2003 06:16 PM
