Seat belt chime annoying!!!
When moving or parking my 5th this chime is driving me nuts. I disconnected the plug at the seat belt under the seat
, no luck. Is there a fuse or how do I defeat this chime. I always use my belts otherwise. Thanks for any help.
Cliff
, no luck. Is there a fuse or how do I defeat this chime. I always use my belts otherwise. Thanks for any help.Cliff
Disconnect that plug again, then use a little wire to jump across the two sides of the receptacle and reconnect the plug. That fools the system into thinking the seatbelt is connected.
Also - check your owners manual. There is a procedure there to disable the chime but the seatbelt light on the dash will stay on.
I agree with you...I ALWAYS use my seatbelt when driving - but it's not needed when maneuvering around a camping spot!
Look in your owners manual,the seat belt chime can be disabled by turning key on/off trick
Would you know what page number in the 2006 owners manual - I have not yet found anything, but then I have been know to be wrong.
As per manual for my 07:
1. With all doors closed and the ignition switch in any position except On or Start, buckle the driver's seat belt.
2. Turn the ignition switch to the ON position and wait for the Seat Belt Warning Light to turn off.
3. Within 60 seconds of starting the vehicle, unbuckle and then re-buckle the driver's seat belt at least three times within 10 seconds, ending with the seat belt buckled.
4. Turn off the engine. A single chime will sound to signify that you have successfully completed the programming.
The system can be reactivated by repeating this procedure.
Just tried it out and it works.
Not sure if the buckles are the same as on my 05 but I took the front middle seat belt and snapped it into mybelt ...no more dingy ding and No light which is a bonus over programming off the dinger.....you still can use the middle belt latch for your own belt when needed , its a handy solution so I hope your buckles match No one ever rides in the front middle of my truck anyway
Take a look at this. On page 2 somebody actually shows pictures on how he did it on a 2006.
http://www.cumminsforum.com/forum/3r...disabling.html
ckennedy
Oct 24, 2004 11:16 PM
339K&Counting
Jun 6, 2004 12:13 AM
Lightman
Oct 27, 2003 04:08 PM
