Rim & Tire Question
Old Oct 7, 2011 | 09:30 AM
richardb's Avatar
Rim & Tire Question
I know this has been beat to death and I have used the Search. I am looking at some used rims that are 18x9 with 0 offset ( I believe its 0 on the inside of the rim it measures 5"), If I put 33's on will I have a rubbing problem. or could I even getaway with 35's
I have an 04 2500 quad Cab I will be installing a 2" leveling kit as well.
Any help would be great.
Old Oct 10, 2011 | 11:18 AM
Lost Lake's Avatar
0 offset means the rim is centered on the bolting surface. The factory wheel is a 7" and has a 43mm positive offset (or is it 48mm?) Anyway, a 9" rim with 0 offset will be out a little more from the truck, but REALLY stick out farther because it is two inches wider. You will contact when you turn methinks.
I had a great offset calculator site, but lost it. Try this one:
http://www.1010tires.com/Wheeloffsetcalculator.asp
Old Oct 11, 2011 | 11:05 AM
richardb's Avatar
Thanks that site is great.
Old Oct 13, 2011 | 12:31 PM
DaUluaHunter's Avatar
I just put the same size rim and tire 18x9 with 5" BS and 33 Toyo MT's while putting on my 3" Thuren suspension and have no rubbing. They do stick out a little, but I like they way it looks.
roxxx
Feb 24, 2008 04:20 PM
wap
Jun 28, 2007 09:53 AM
chw
Jan 9, 2007 09:12 PM
robs3500
Dec 19, 2006 10:42 PM
redryder64
Dec 11, 2006 10:59 PM
