Reverse Feed to trailer
Old Oct 30, 2004 | 05:30 PM
Nvisable's Avatar
Question Reverse Feed to trailer
I'm trying to hook up addtional reverse lights so I can see better at night. But I can't seem to find the reverse wire to the trailer hitch plug.
According to a couple of searchs it's either violote or yellow. I don't have a violote and my yellow doesn't show any voltage when the Key is on and the truck is in reverse.
Any clues to the correct wire color would greatly be welcome.
Thanks.
Old Oct 30, 2004 | 08:01 PM
gsbrockman's Avatar
As best I can tell, there's no provision for reverse lights in the 7-round trailer wiring connector. You may indeed need to get a 12V power wire to a relay and have the relay energized from a wire form the reverse lamps near the taillights themselves.
Greg
Old Oct 30, 2004 | 08:43 PM
Gypsyman's Avatar
On my '03 I believe it's the center pin.
Old Oct 30, 2004 | 10:39 PM
Jeff in TD's Avatar
My 5er is a toyhauler, so it has a couple of porch type lights on the back, each with a rocker switch on the light housing.
Since whenever I have to back into someplace dark at night, I either have a spotter or get out and look myself, I just turn those on while I'm back there...
Perhaps it would be easier for you to do something similar- Just mount a porch light on the back with a manual switch on the light, wired to the trailer's power... As a side benefit, you would have an extra exterior light, even when unhooked from the truck, which could be handy.
Old Oct 30, 2004 | 10:46 PM
firestorm's Avatar
I believe that is the standard set-up. However, when I hooked mine up, I used the hot from the trailer plug to feed the lights, and tied into the reverse light wire to trigger the relay.
Old Oct 31, 2004 | 07:06 AM
handymantim's Avatar
According to my 04 service manual it's the WT/LG wire.
My trailer has reverse lights built in from the factory and they illuminate when I put the truck in reverse. All factory wiring on truck and trailer.
Sorry but I gotta ask....do your truck reverse lights illuminate with the key on and the shifter in "R"?
Old Oct 31, 2004 | 08:09 AM
Nvisable's Avatar
[i]
Sorry but I gotta ask....do your truck reverse lights illuminate with the key on and the shifter in "R"? [/B]
Yes, That's the first thing I looked for when I walked to the back of the truck. I'll Test the wt/lg wire here in a bit.
Thanks for the help.
Old Oct 31, 2004 | 02:52 PM
natstayl's Avatar
If it's stock to the 7 pin RV connector, it's the center pin that has the backup lite feed
Nat
Old Oct 31, 2004 | 04:13 PM
HdPower's Avatar
Just installed my White Knight reverse lights the other day and the reverse is the white wire with the green stripe...this is on my 2004.5 not sure if the 2004 is the same though.
Old Oct 31, 2004 | 09:31 PM
Nvisable's Avatar
It was the White/ Green Strip on mine to. I have the 2004.5. I guess I should up date my sig.
Old Nov 2, 2004 | 04:08 AM
Dodgezilla's Avatar
You could always feed from the 4 pin connector under the bumper and install a toggle switch in the cab if you cant figure it out. I'm thinking about doing the same thing.....
xtoyz17
Oct 7, 2007 06:46 PM
ta3834bbl
Jan 17, 2004 05:58 PM
bigredbrick
Apr 29, 2003 12:31 PM
VinDiesel
Nov 8, 2002 09:22 PM
