Resetting TIPM?
Old Nov 8, 2010 | 05:14 AM
Dieselhed's Avatar
Resetting TIPM?
Can a resetting of the tipm only be done with a Starscan or will unhooking the batteries completely for an hour or so do it? Are there any fuses inside of it that can be replaced? Gonna unhook it today and look for any signs of corrosion underneath it. I still don't have a left rear turn signal and this is pissing me off.
Or is there anyway to just bypass the tipm left rear turn signal circuit to just get the thing to work.
Old Nov 8, 2010 | 10:14 AM
Grey Wolf's Avatar
If your speaking of the '06 in your signature, yes Dodge or someone with their scan tool has to re-set it. A poor design indeed...
Old Nov 8, 2010 | 01:38 PM
Dieselhed's Avatar
Great. I guess theres no way to find out if or how many times it's been reset is there? And yes the '06
Old Nov 8, 2010 | 04:39 PM
Grey Wolf's Avatar
That I don't know, but if you have it reset I would imagine they would be able to tell?
Old Nov 8, 2010 | 04:57 PM
BigIron70's Avatar
Cummins Guru
Read TSB may apply to your truck
If a Totally Integrated Power Module (TIPM) is being replaced for a B178C, B166C, B2215 or P1277 fault code, please refer to Service Bulletin 08-021-06 for flashing the TIPM.
Service Bulletin 08-021-06 only applies to vehilces built prior to 04/03/06.
Old Nov 9, 2010 | 10:00 AM
Dieselhed's Avatar
Thanks BigIron70. I don't have any codes though and the turn signal worked for about 2hrs. after I bought the truck then quit. I'll take it in and see what they say. Any way to just bypass the **** thing?
Old Nov 9, 2010 | 10:46 AM
Dodgezilla's Avatar
I assume you have checked the wiring to verify if there is power going to the light or not??? If it were me, and I didn't want to bother with it anymore or just didn't want to spend a bunch of $$$ for a dealer visit, then I would simply get a length of wire and splice into the front turn signal. Or, better yet, if there is power at the secondary trailer plug I would splice into that. In fact, back when I had my 03 truck I had to do just this because one of my tails wasn't working right. I can't remember if it was running lights or turn signal but I know I fixed it easily......
Old Nov 10, 2010 | 08:38 AM
Dieselhed's Avatar
I thought about that but the '06 ^ have the tipm instead of a standard fuse box to control the lights and a couple of other things. I'm afraid if I tap into anything I run the risk of the tipm seeing a voltage change and shutting down the output signal to the front turn signal which is what I think happened to the rear. I only need this thing to work for about 5 min. to get the truck state inspected so I can tag it. I could care less if it works or not but they will never pass it if it isn't working. Sux
Old Nov 10, 2010 | 08:48 AM
Dodgezilla's Avatar
I'd still try tapping into the trailer plug to get it working even if only for that day.
Old Nov 11, 2010 | 06:40 PM
heminfiver's Avatar
Just had my Tipm module replaced because 7 pin hook up wasn't for trailer wasnt functioning the left bake and left turn signal...however since i have gotten it back my turn signals now flash slow then fast again for some reason...
The module was 757.00 and 240 for labor... lucky mine was still covered under my extended warranty....
Old Nov 12, 2010 | 09:42 AM
Dieselhed's Avatar
$1000 to have a turn signal work correctly when all it should take is a simple fuse. Once again technology not in our favor.
Old Nov 12, 2010 | 06:45 PM
Grey Wolf's Avatar
My exact sentiments Fortunately like heminfiver my TIPM was replaced under warranty about a year ago, but if there's a next time my wallet will most likely be much lighter, thank you Chrysler engineers
Old Nov 14, 2010 | 07:42 AM
dezeldog's Avatar
Well speaking of electrical probs heres my dilema. My fogs are wired to a aftermkt switch that is powered up from a jumper wire from the left pking light. With this I had the relay go bad so I replaced it and did the "fogzilla" at the same time. Now after about 15 min. with them on it will blow the #34 fuse, which is 10 amp. and shut down left front and rear pking lights and the left license plate light.... Help TIA
Jim
newtododge
Apr 27, 2006 11:53 PM
tristan21
Mar 20, 2006 06:32 AM
running4bhs
Dec 31, 2005 02:02 AM
Geographic Void
13
Sep 8, 2005 04:00 PM
Sean S
14
Nov 15, 2002 11:40 AM
