resetting ecm
resetting ecm
So for the past couple months my windows have been out of commission. I got a PM from someone with the same problem and he said the dealer reset the ecm. Now, disconnecting the batteries for a couple hours will reset it correct? If i do this, do i need to take the Smarty back to stock or are we talking about different things.
06 and later? Probably talking about your TIPM Gateway module. It is the "body" computer of the vehicle. It's like a firewall. You activate something switch-wise on the truck. That input has to go through the cluster for what the input does, and then it goes to the TIPM under the hood to get permission to send the the voltage to respond. If it doesn't find the software to allow the voltage to run this function (like windows) it won't send the power. If it seems to lose it's memory, then it has to be re-configured. That does involve a trip to the dealer, where they will have to reload the software for your VIN into the TIPM from Chrysler. Very rarely do these have to be replaced, regardless of what your dealer will say. The techs only get paid their worth if they replace something. Like 1.5-2.0 hours to replace this module, or less than 1/2 an hour to just reprogram it. Depending on their internet connection it could take up to an hour to do the reprogram.
Chris
Chris
Chris
Chris
tristan21
Mar 20, 2006 06:32 AM
Geographic Void
13
Sep 8, 2005 04:00 PM
Sean S
14
Nov 15, 2002 11:40 AM
