Replacing heater core in 06 Dodge ram
Old Sep 9, 2009 | 03:04 PM
chucka's Avatar
Has anyone on here ever replaced the heater core on a 06 Dodge Ram? My son has a 06 3500 mega cab & the heater core is out of it. We was wanting to replace it ourselves, lookes pretty tuff. Any advice? Thanks Chuck
Old Sep 9, 2009 | 03:50 PM
Jeff in TD's Avatar
I've had the dash and the HVAC box out on my 06 quad cab.
It is time consuming, but nothing particularly complicated. The only tools the typical home garage wouldn't have would be the stuff to evacuate the refrigerant and to dry and refill the AC system.
Old Sep 9, 2009 | 04:24 PM
chucka's Avatar
When you say remove the dash, do you mean the cover & the tubing metal structure behind the dash cover, to get to the hvac box? Thanks for your help.
Old Sep 9, 2009 | 06:44 PM
Jeff in TD's Avatar
The entire dash comes out as an assembly.
This thread about taking the HVAC box apart, and the thread it links to about removing the dash will be very helpful.
https://www.dieseltruckresource.com/....html?t=210483
On the 06, the fluid bottle has to be unbolted to get to the other studs holding the HVAC box to the dash (different from the one shown in the thread).
Also, if I were going to do it again, I'd pull the extra couple bolts and remove the steering column completely. Though you can do it with the column lowered down as in my photo, the extra couple seconds to remove it would get it out of the way.
Old Sep 9, 2009 | 06:52 PM
Jeff in TD's Avatar
P.S.
I just saw these were your first posts. Welcome to the forum. I've learned a ton from the wealth of information here.
Old Sep 9, 2009 | 09:10 PM
chucka's Avatar
Thanks for the welcome & the info!
Old Sep 11, 2009 | 07:04 PM
chucka's Avatar
With the dash out of the way, will i be able to take the bottom of the havc box off? I didn't want to mess with the ac unless there is no other way around it. Thanks Chuck
Old Sep 12, 2009 | 03:01 AM
Jeff in TD's Avatar
No, I think (but I'm not positive) you will have to remove the HVAC case from the cab, which does require unhooking the AC evaporator.
Here's the HVAC case.
The heater core is mounted horizontally, between two sets of blend doors.
Old Sep 12, 2009 | 10:43 AM
Mlucas's Avatar
Wow, that job looks daunting! I don't know if I would have enough courage to strip my dash off.
Old Sep 12, 2009 | 04:17 PM
Jeff in TD's Avatar
It really isn't as bad as it looks. A bunch of trim comes off, a bunch of electric connectors come off, and there's some bolts along the front by the defroster, a couple up from the column support, and a few bolts on each side.
canadakonrad
Dec 1, 2010 08:41 PM
wdimig
Sep 29, 2010 07:38 PM
case310350
Jun 18, 2009 06:54 PM
Luckyrogue
Dec 15, 2008 11:26 AM
eng208
Nov 12, 2006 12:18 PM
