Rear window leaking
Old Apr 11, 2017 | 06:13 PM
woj64's Avatar
Rear window leaking
Tracked the lake in the back left foot well to an apparent leak around the rear window. Apparently these are not considered removable (at least not and be able to reuse it). So my options are $330 to the local Safelight guy or reseal it myself any suggestions?
Old Apr 11, 2017 | 08:33 PM
Mexstan's Avatar
Mine leaked years ago, so I just went to Home Depot and bought some black sealant and resealed it myself. No more leaks. Then a few years ago did something stooopid and managed to break one side of the glass. A wrecker had a good used back window assembly and they removed my old one and installed the used unit. It looks great and never has leaked, even in the hardest tropical rains.
Old Apr 11, 2017 | 08:40 PM
death row dave's Avatar
Power sliding back glass has super small drain tubes . They are known for plugging up and flooding the wells . Not everyone can install a new glass without crimping the tubes . Solid back glass is a leakfree answer .��
Old Apr 13, 2017 | 06:31 PM
woj64's Avatar
Yeah its not a power window just a manual slider, that would just be more to break. I guess I'm going to go with the silicone and prayer method, one of those should work.
Old Apr 13, 2017 | 07:22 PM
Have you verified its not 3rd brake/bed light ? They are noted for leakin also and show up in the same place
Old Apr 14, 2017 | 04:39 PM
woj64's Avatar
Yup put tissue paper in the area under the light but above the window got water to run into the cab pulled the light again and the tissue paper was dry. As an update talked to the the local glass guy before I siliconed the window he advised very strongly against silicone and suggested primerless urethane windshield adhesive. Not cheap at $28 a tube from Autozone. Couldn't find true primerless version but as I'm using it to reseal not mounting the window I went ahead with that gotta give a couple of days before I can test it.
Piston_bully
Feb 1, 2012 04:45 PM
raven392003
Oct 29, 2007 11:39 AM
rjm022
Nov 6, 2006 11:57 AM
roadie00
Dec 22, 2005 07:10 AM
Sidewinder
Nov 3, 2004 08:09 AM
