Programming new key
Old Nov 14, 2006 | 03:33 PM
Juiced06's Avatar
Programming new key
Before i head to the dealer and spend $45 for programming does any one know how to with only one key. I know the manual shows how to with 2 keys but is there a way to with one key???? 2006 Ram 2500 CTD black key with remote
Old Nov 14, 2006 | 05:49 PM
03WVJay's Avatar
I dont think there is a way with only one programmed key.
On a similar note, on the keys that have the fob built on them like the 06 keys, how do you program the remote keyless entry? Is that taken care of when you program the unprogrammed Sentry Key with two "good" keys?
Old Nov 14, 2006 | 07:56 PM
handymantim's Avatar
Sorry but you need 2 keys.
After you get your new expensive key, find additional cheap keys on eBay and program them yourself for future loss(es). Make sure they have the same codes (look on the back of your key for the codes). Obviously the new keys will have to be cut also.
Old Nov 14, 2006 | 09:53 PM
sdarchery's Avatar
You only need one programed key fob. I have done it many times. Here's how you do it!
1. Enter vehicle and close all doors
2. Fasten seat belt turn ignition to on let chime stop.
3. Press & hold the UNLOCK button on the programmed key fob for 4 seconds. Within 6 seconds with the unlock button still depressed, press the panic button. When a single chime is heard, release both buttons. The chime indicates the system is in program mode.
4. Press and release both the lock & unlock buttons simultaneously on the fob to be programmed. A single chime will be heard. This indicates the fob has been recognized.
5. Within 4 seconds of hearing the chime, press and release the lock and panic button on the fob being programmed. A single chime will be heard. This indicates the fob has been programmed.
6. Repeat steps 4 and 5 for up to a total of 4 fobs.
7. Turn off ignition.
8. Cycle the ignition after 60 seconds. With in this time the vehicle will exit the program mode and all fobs should function normally.
Old Nov 14, 2006 | 09:57 PM
sdarchery's Avatar
Maybe I spoke to soon. Looks like you haave only a key with a built in fob. I'd try it my just for ***** and Grins
Old Nov 15, 2006 | 01:42 AM
gray ghost's Avatar
sdarchery,
I'm a little confused.I have the gray key(2004.5).Using the method you describe,can I program a new key with only the one key that I have?The other went overboard.I hope I can.It will save me $175.00 and the hassle of going to the dealer.Thanks in advance.
Old Nov 15, 2006 | 01:46 AM
gray ghost's Avatar
My bad,I think that is the method of programming the FOB and not a new key.
Old Nov 15, 2006 | 11:47 AM
79warlock's Avatar
You should be able to program up to eight working ignition keys on you truck, but as it has been stated before, you can't program them yourself unless you have two programed keys to begin with.
Old Nov 15, 2006 | 01:31 PM
sdarchery's Avatar
I have programmed 3 fobs and started with only one. Take it for what its worth. This isnt something I read, I have actually done it.
Old Nov 15, 2006 | 02:17 PM
79warlock's Avatar
I know you can do it, but he isn't programming a fob he wants to know how to program a SKIM key.
Old Nov 15, 2006 | 08:39 PM
03WVJay's Avatar
I think I may have started the confusion (sorry) so maybe I should be the one to clearify. Let me know if this is incorrect.
You cannot program a gray key (2003 type) or a black key with the built in fob (2006 type) unless you have two programmed keys.
You can program a fob (2003 type seperate from key) or a fob (2006 type made as part of the key) with only one working fob using the method described by sdarchery in steps 1-8. Is this all correct??
I think everyone is correct. I just threw a wrench in the works on my first post when I switched the question from key to fob programming.
Thanks for fob programming info.
Old Nov 16, 2006 | 06:16 AM
79warlock's Avatar
You are correct except for the SKREEM key(combined key/fob). You still need two programmed keys for that, the fob is programmed when the sentry key part is coded.
Old Nov 16, 2006 | 05:03 PM
03WVJay's Avatar
I thought that may be the case for the SKREEM key.
Thanks for the clarification 79warlock.
Old Apr 24, 2017 | 02:59 PM
Don Coates's Avatar
can you tell me what key I use in the IGNITION, the original one or the one that needs Programed?
Old Jun 19, 2017 | 01:37 PM
Jody Ybarra's Avatar
Thank you for posting this, I just want to know if I do this and do not preform it right will it mess up the only kekey I have?
JasonSauce
Aug 14, 2011 02:27 PM
doorguy
Jun 28, 2011 10:03 AM
tool
Mar 26, 2009 09:00 PM
Arkapigdiesel
16
May 11, 2007 09:28 PM
GotBoost?
Dec 31, 2004 10:01 AM
