perform service
Old Nov 19, 2011 | 06:31 PM
Blacksunshine's Avatar
perform service
is there a way to shut this off without going to dealer, smarty wont erase it
Old Nov 19, 2011 | 06:54 PM
AH64ID's Avatar
Is it the oil change reset?
Old Nov 19, 2011 | 10:58 PM
no the clean egr/change ccv reminder
Old Nov 20, 2011 | 08:58 AM
AH64ID's Avatar
PERFORM SERVICE INDICATOR - RESET
The “Perform Service” message will display on the EVIC each time you turn the ignition switch to the ON/RUN position to indicate a emission maintenance is required. To reset the “Perform Service” indicator system (after performing the scheduled maintenance) refer to the following procedure:
1. Turn the ignition switch to the ON position (Do not start engine).
2. Press and release the brake pedal two times.
3. Fully depress the accelerator pedal slowly two times within 10 seconds.
4. Turn the ignition switch to the OFF/LOCK position.
Old Nov 20, 2011 | 11:53 AM
thank you sir, much appreciated
Old Feb 28, 2012 | 04:29 PM
jivemother's Avatar
outstanding worked great
Old Mar 2, 2012 | 09:34 AM
EverydayDiesel's Avatar
Do you still need to change this filter if you removed egr and dpf?
thaimonkee
Mar 2, 2011 08:58 PM
bekec
Feb 14, 2011 09:16 AM
SilentTrouble
Oct 14, 2010 10:55 PM
Outwest
Oct 19, 2009 07:38 PM
GMScott
Nov 2, 2007 03:01 PM
