Passenger AC not cold
I've searched the forum and come up dry.... My 04 has extremely cold AC coming out of the drivers two vents, but the passenger two are barely cold until you come to a full stop, at which time they slowly cool down to the temp pushing out of the drivers' ones.
Any guesses?
Any guesses?
Just had the same thing happen to mine...had it evacuated and recharged , and it`s better now , but I swear it`s still not as cold on the pass. side , but everyone that`s ever in that seat is always cold anyway
Yeah, the way the thing is set up, the air going through the side of the evaporator where the inlet is goes to the driver, and the air where the discharge is on the evaporator goes to the passenger.
If most of the liquid refrigerant has already vaporized before it gets to the other side of the evaporator...
P.S. In this system, hot coolant flows through the heater core full bore all the time, and temp is controlled by blend doors directing a portion of the air through or around the heater core.
AC cooling performance can be improved greatly by installing a valve in the heater line. Cost me like $12.
i don't think it would be because it needs a charge (of course I could be wrong), but the cold air coming out of the drivers side is so cold it'll make you hurt, and still warm on the passenger. The blend door sounds a bit closer to my situation. Where could I find more out about this door?
https://www.dieseltruckresource.com/....html?t=210483
I'd check charge first, though, since it is simple and known to cause a temp difference between driver and passenger side.
If yours is extreme, you could very well be right, but pulling the HVAC down is an all day job that requires evacuation of the refrigerant anyway, so I would still check charge level first.
Jeff
Yeah, I put a valve in the heater core line. Auto parts stores can provide you with a valve designed for that purpose. The heater line only runs through the heater core and back to the block. ISB engines are used in many applications where there is no cab heater, and it hasn't caused me any problems.
I've mainly noted a difference when it is up around 110 f, and I'm working the engine.
I posted a pic of the valve installation on the heater treater door thread.
https://www.dieseltruckresource.com/...s-t271212.html
Spooler
96
05-07-2012 09:11 AM
hognutz
14
09-15-2009 06:53 PM
Blessed
04-06-2007 03:18 PM
BamaMac
03-30-2007 03:42 PM
rockinw
24
07-21-2006 04:55 PM
