PacBrake airbag kit install
Ordered up a PacBrake airbag kit and took a few picts when I installed it. Thought I would post em up for everyone's viewing pleasure.
Here't the before picts of the rear end.
Heres the kit as I got it. This will be going on the truck in my sig. The packaging was great. Everything was labeled, instructions were clear, and all parts were well packaged. I liked that the bracktry was all hammerite painted.
I didn't take picts of all the steps cause it is just a bolt on affair and very straightforward.
The upper brackets take the place of the factory bumpstops and the lower brackets clamp around the axle tube. I ran the airlines to the rear license plate which made for a clean easy accessable place to fill or check each bag independently.
I plan on putting an air system on in the future so I can operate the bags from the cab, air horns, air tools, etc...
I'll be able to give more feedback when I pull a load in a few weeks. (30' Gooseneck with our XJ and a buddy's LJ)
This was taken about a month ago and should help keep the rear end level.
It was amazing how quick the rear end raised up when the bags were inflated. Was about a 2" difference in height. Since the bags are so small you have to give the air in short bursts to keep from over inflating. I filled them to 90 psi for a leak check and everything seems to be holding well so I'll zip tie and spit loom everything this afternoon and put the spare tire back in.
I just installed the Rite Ride tonite, easy install and i am happy with it.
Installing the 2" leveling kit in the front was a pain in the ***, but all in all i like the look of the truck now, it sits like a dodge is too sit
hi
i have the air lift air spring brand on mine and from the pic thay look like the same bags ?
mine have the number 5813 molded on the bag .
also mine mount on top of spring between axel and frame ,so plenty of room between ex pipe and bag no shield .
unloaded i only carry 20 psi in them as 30 gives a bouncy ride .
with open car trailer and car i run 35 for a smooth ride .
I don't know if they support or not but Geno's has em.
Harold may be able to answer the airbag question but I doubt they are PacBrake's unless they have Pacbrake molded into the bag.
One of the reasons I went with this kit was that it didn't go between the spring and frame cause that is where some of the GN hitch brackets are.
I just got back from a trip this weekend and ran 30 psi in them and they were very stable. I run 10-12 around town.
The hardware was great, all hardware fit nice, brackets were very nicely painted and everything labled. I'd recomend them to anyone.
hi
RoadDiesel
Jul 22, 2014 05:34 PM
AH64ID
Jun 7, 2008 04:58 AM
