Non Fog lights to Fog lights
Old Oct 3, 2006 | 04:29 PM
topless's Avatar
The install was the easiest lights I've ever done. Including just changing a bulb in some of my cars in the past.
Old Oct 4, 2006 | 07:09 PM
Robert P's Avatar
ok got the switch today but the fog light wont be until tomorrow i installed the switch, but for some reason the little green light doesnt light up when pulled out do the fog lights have to be plugged in for that to work?
i got the factory switch that has the dimmer with it.
Old Oct 5, 2006 | 01:02 PM
topless's Avatar
I don't know, I put the lights in first.
Old Oct 5, 2006 | 05:07 PM
ShawnQ's Avatar
The green light probably requires the foglights to be plugged in as well to complete the electrical circuit.
SQ
Old Oct 5, 2006 | 05:44 PM
Robert P's Avatar
well i put the lights in and they work but still no green light. but im really not too much worried about the light. thanks though
Old Feb 2, 2007 | 08:57 PM
smittyusn's Avatar
how hard is it to replace the headlight switch, whre does the relay go in the fuse box for the fog lights.
Old Feb 2, 2007 | 09:24 PM
JohnInNH's Avatar
Don;t you have to have your ECM programed to recognize that you have them in a 05 and later?
I bet my dealer will charge me $85 to do it!
Old Feb 3, 2007 | 09:28 AM
topless's Avatar
My is an '05 and there was nothing more to it than the others explained. The aiming of the lights took longer than the install. I also re-aimed my headlights, since distance is the same, only the drop is different. Huge difference when driving in bad weather.
Old Feb 4, 2007 | 05:49 PM
les1cam's Avatar
Fog light switch for '06
I have the fog light kit and it calls for the dash to be pulled to install the new light switch. How did you that own the '06's get around that?
Old Feb 5, 2007 | 09:14 AM
JohnInNH's Avatar
Bump.... Yes, HOW DO you get the switch out? ... (or take the dash apart)
Old Feb 5, 2007 | 10:40 AM
ptgarcia's Avatar
Getting the dash apart is easy, but you have to do it in a particular sequence. In another thread someone posted parts of a manual showing how to do it. I'll poke around and see if I can find it.....
Old Feb 5, 2007 | 10:58 AM
JohnInNH's Avatar
Thanks... LOL I STILL can't seem to find my head lamp adjusters as well.. Torx 20 some place between the lamp and the radiator. I have not searched in the day or at much length. My lights are way to high.
Old Feb 5, 2007 | 11:01 AM
ptgarcia's Avatar
To find the adjuster, pop the hood and on the inside edge of the headlight there is a rubber seal. Fold the rubber seal back with your hand and you'll see a deep hole at about the horizontal centerline of the light. Shine a light in that hole and you'll see the torx screw adjuster.
Old Feb 5, 2007 | 08:35 PM
charcoal600's Avatar
Originally Posted by topless
Thanks to this thread, I just ordered a set for my truck.
What he said; also just placed an order for the kit, I've been wanting to install these on my rig for a while now.
Old Feb 5, 2007 | 10:53 PM
MoparNut's Avatar
Replacing Dash switch
Just added a kit last weekend. The instructions "show" you (there are no words, only diagrams) to remove the panel around the radio first (if you have the floor mounted cup holders I think it needs to come off first), then the panel below the steering column, then the panel around the instrument panel-this also has the switch mounted to it.
What I did is remove the panel below the steering column (2 screws on the bottom and pull it off). Then remove 3 screws holding the switch/instrument panel. Then pull the panel out on the left side until you can reach in behind the switch and unplug the wire harness from the switch. May be hard to do if you have big hands. There are 3 screws holding the switch. Use a 8mm socket or a very short philips screwdriver and remove the screws.
