No air flow in cab
Old Jul 9, 2008 | 02:44 AM
bighamor's Avatar
No air flow in cab
Everything was going fine today in 100 plus heat here in San Jose. AC was blowing cold, and fan was fine. I was working and came out to run to the store and turned the fan and AC on and I could hear the clutch on the compressor click but no air coming out of vents. Turned everything off including the truck and restarted with same results. I checked the fuses for anything related to fans and HVAC in the fusebox, but all seemed fine. I did notice a very small amount of air coming out of the defroster vents at any fan setting later on in the evening. What should I do next?
Old Jul 9, 2008 | 02:48 AM
julang's Avatar
on ice
Try to turn warm about few minutes,does any changes?
Old Jul 9, 2008 | 02:57 AM
bighamor's Avatar
I dunno... I didn't try that but I will in the morning. Thanks
Old Jul 9, 2008 | 06:51 AM
bigtruck's Avatar
Could be the Relay, not sure where its located on your truck.
Old Jul 9, 2008 | 12:07 PM
bighamor's Avatar
Solved the problem this morning. I remembered that sometimes when I turn the truck off, the fan keeps running if it is in the on position. I took the fan motor out of the hvac housing and set it on the floor with it plugged in. I jiggled the key around a bit in the ignition and the fan fired right up. Apparently, my ignition switch is getting a little tired. I put some WD40 in there and am hoping for a little more time... BTW the fan motor runs off a 40 amp fuse labeled "ignition/acc" in the fusebox. Thanks for your replies, this forum is awesome.
Old Jul 9, 2008 | 09:32 PM
mowmone's Avatar
if i am correct the power that runs the fan runs though the ignition module. had it happen. watch it. it will melt the harness plug from poor connection and overheating. needs to be addressed or a bigger mess with wires could follow.
herb
Jul 18, 2008 08:25 AM
ralphyboy
Jan 17, 2008 08:35 PM
8mpg
May 22, 2006 01:35 PM
1ST GEN.
Mar 1, 2003 11:41 AM
1ST GEN.
Feb 22, 2003 03:59 PM
