No ac blowing hot air
Old Jul 9, 2010 | 08:53 AM
04ctd's Avatar
FWiW, my 06 AC compressor went out, and had +12v at the compressor plug.
Dodge sells new compresspors as rebuilt for $325.
Old Jul 9, 2010 | 01:56 PM
Vert's Avatar
I'm worried that the compressor is going to be the next step. My wife hasn't gotten back to me as to the results from this morning. My contact at Chrysler Parts Center sells them for $260 if I remember.
Old Jul 11, 2010 | 08:22 PM
Mr Jerry's Avatar
Originally Posted by Vert
Got the TIPM, my dealer told me I got it cheaper than he could get them for and I got it from a Chrysler dealer.
Anyway, it should be installed today, they told me .5 hours for the install and electronic adjustments. That should cure the AC clutch problem as it goes through the TIPM which was exhibiting other issues as well, such as making door locks inoperative and putting the drive train in neutral through the 4x4 switch. At least that's what the mechanic at the dealership surmised.
Vert if the dealer tells you you need a compressor, most likely you will need just the clutch coil behind the clutch pulley,not sold seprate from the dealer but this is about the only thing that ever goes wrong with a compressor, pull the connector loose at the compressor, with a meter check if any resistance between those 2 wires, if none you need just a clutch coil,,,,I just did one for my neighbor today,and i can let you know where to buy one for about 50.00.
Old Jul 11, 2010 | 10:22 PM
Vert's Avatar
Thank you, I appreciate that analysis. The dealer installed the unit and it cured the problem to date. So, the compressor seems to be working.
Amazing how many trucks are exhibiting the same exact issue. Its the darn fuse box...is what a TIPM really is. Amazing.
NJMurvin
Jul 4, 2013 12:03 AM
notblowingsmoke
May 14, 2009 12:46 PM
code7
Aug 6, 2006 11:41 PM
duallydave
Aug 7, 2005 09:38 PM
