Need advise from the wise!
Old Jun 19, 2008 | 11:43 PM
ACTD4E's Avatar
I am looking for another truck! I'm looking 2003 to 2005 dually with standard trans. Is there a certain year that had problems with certain things? Thanks in advance!
Old Jun 20, 2008 | 03:42 AM
TexasCTD's Avatar
The 03-04.5 trucks have failing lift pumps mounted behind the stock filter housing. Easily remedied with a Walbro pump or FASS, which you will need anyway if you plan to up the power. Starting in 05 they went to the intank design pumps...which seem to be doing well. But you still gotta put on an aftermarket pump if you want boost up to significant power.
On the early 05's, Dodge messed up and switched to "PLASTIC" intercoolers which often blow. You will probably want to change it to a metal one. Later 05's had metal...as well as....earlier trucks.
They are all good. Buy any with confidence.
Old Jun 20, 2008 | 05:47 AM
Hounddog's Avatar
Two manual trannys used in 05. The NV5600 and the G56.Not really a issue with eaither but each one drives differantly.Ac issues and heat and ac issues with dash blend and recir doors.Seems ALL models are affected with that.
BMH95
Jun 14, 2007 09:07 AM
Poppasmurf
Apr 10, 2006 04:00 PM
Boatnik
Aug 14, 2005 10:57 PM
dodgediesel4x4
Jun 30, 2004 12:24 AM
DynamicalyUnstable
May 6, 2004 12:14 PM
