Name that part!
Old Oct 11, 2006 | 10:52 AM
fredbert's Avatar
Name that part!
This has been bugging me for a long time, so here goes. There is a rubber hose (about 1/2" diameter X 18" long) coming from the rear brake line tee. The other end is clipped to the shock tower above it and contains some sort of mechanism. Is this part of a proportional rear braking system, meaning the greater the load in the bed, the greater the brake fluid pressure applied to the rear brakes? If so, how the heck does it work? If not, what the heck is it? Do our trucks even have proportional rear brakes? Thanks, guys!
Old Oct 11, 2006 | 10:54 AM
trik396's Avatar
I've wondered what that was also... I thought it was some sort of bleeding device for air in the lines, but that really doesn't make much sense....
Old Oct 11, 2006 | 11:52 AM
John Halter's Avatar
From: somewhere in northwestern ohio....Mansfield, Oh
I need to go out and look but on a Ford that is the rear end vent hose combination brake line tee . I am not sure if Dodge uses the same set up but that is my guess until I climb under and look .
Old Oct 11, 2006 | 12:04 PM
Peterbilt's Avatar
It's probably the rear differential breather tube.
Pete
Old Oct 11, 2006 | 12:13 PM
xyzer's Avatar
Rear differential vent hose.....the bolt that holds the brake lines is hollow and the tube slips over it and they run it up high so it doesn't get water in it...The thingy on the end is some sort of breather. That is my guess without going out and lookin under my truck. A lot of cars and trucks do it that way.
Old Oct 11, 2006 | 10:38 PM
DmaxEter's Avatar
Yes, it is the diff breather tube. The thing on the end keeps crap from getting in to it.
Silverfox99
Apr 23, 2007 11:43 PM
tomd
Apr 14, 2007 01:42 AM
ouchman
Jun 8, 2006 10:44 PM
mr T
Jan 15, 2006 12:29 AM
