mystery bell
Old Feb 21, 2006 | 01:52 PM
2500dan's Avatar
mystery bell
I have a 2003 2500 w/ 40k miles, and have just installed a 100gal aux tank. Everything operates fine except I occasionally get an interrior chime. Is the truck telling me something is being coded in the computer or ? Was just wondering if anyone else has experienced this issue.
Old Feb 21, 2006 | 02:23 PM
jbeg's Avatar
Mystery Chime
I had an issue that started out the same. At no particular time, I would get a "bing"....just once and then not again for a while. No dash lights. Eventually, about 3 weeks later, the chimes got closer and closer together. I finally caught, out of the corner of my eye, a light on the dash. Waited for it again....."lamp out". Ended up having to change out both tail light circuit panels. Some of the '03's are put together with a faulty circuit panel, that the tail lights plug into (brake light socket on mine). $25 bucks a piece and a simple install. Don't know if this is the same problem, but sounds familiar.
Old Feb 21, 2006 | 02:29 PM
2500dan's Avatar
Thanks again for the insight. I will check it out. Is there an easy way to determine if it is defective?
Old Feb 21, 2006 | 02:44 PM
cincydiesel's Avatar
My Dads 03 does that and it is irratating as hell. Replaced the passenger side brake bulb and went away for about 3 months now its doing it again. All the bulbs are working fine and everyonce in a while the "lamp out" will flash. Wonder if its the circuit panel ?
Old Feb 21, 2006 | 02:59 PM
bigdav160's Avatar
The sockets like to heat up and burn. I just squeazed mine down with needle nose pliers and replaced the bulbs.
Old Feb 22, 2006 | 10:29 AM
SafeHarbor's Avatar
Wow, guys, is this forum ever useful! I've heard the mystery chime every now and then, and I always look at the gauges, look at the lights, check the seat belt, check the door. And I never find anything to link it to.
I've been just chalking it up to gremlins, but now I have something to look for.
Thanks!
Old Apr 3, 2006 | 03:20 PM
grdnw523's Avatar
part #
Does anyone know the part number to the brake lamp cluster? cuase mine has started dinging off and on now for a week.
Old Apr 3, 2006 | 06:31 PM
SOhappy's Avatar
Mine did that once right after I bought it and my voltmeter dropped to "0" I thought "oh boy, shoulda' got the Chebby instead!" pulled right over and popped the hood. Nothing. I started it back up and it's been fine ever since.
P.S. That was nearly three years ago, and I'm glad I didn't get the Chebby.
Old Apr 5, 2006 | 12:38 PM
Duallydog's Avatar
My lamp out came on when the flat bed was put on. Had to take it to a dealer and get it flashed. It would chime everytime I hit the break or put a signal on. And the signal would flash faster than normal. Thats been over 30,000 miles ago. Sorry, I'm getting nostalgic.
eswartz
14
Oct 7, 2003 01:43 PM
Hawkeye
Sep 23, 2003 08:22 PM
nevrenufhp
Jun 26, 2003 06:48 PM
51
Jan 14, 2003 01:04 PM
Monty
Jan 13, 2003 09:31 AM
