LR window won't roll up
Old Apr 17, 2010 | 08:01 PM
RWDCelicadude's Avatar
I went to a drive through today and the guy in the back seat rolled the window down and it wouldn't roll up. I swapped switches between the rear doors and that didn't change anything. I pulled the door panel and got the window rolled up for now (it's pouring) but I was wondering if this was a common problem. I'm getting a varying voltage to the constant power wire at the door so I'm thinking that the master switch is the problem. Any thoughts, hints, tips? I don't have time to work on it any more today but I'll do a little more tomorrow and maybe get it more figured out.
Old Apr 18, 2010 | 12:59 AM
HMX-1's Avatar
Do you have the lock out switch to kill power to the rear switches? It could be your problem if its going south on you.
Old Apr 18, 2010 | 01:48 AM
I do have it but it's not on and all the other windows work normally. The power to the RR window is a steady 12V and the power to the LR window varies from 9 to 12V.
Old Apr 18, 2010 | 10:52 AM
megacabdad's Avatar
Get in there with a can of white lithium grease and lube away.
Old Apr 18, 2010 | 08:02 PM
Meatball's Avatar
happened to me would go ddown and not up and other stuff. i just pulled the switch cluster out pushed window up while wiggling the plugs in the back......its cheesy but it works..sometimes when things don't work...all they need is a lil attitude adjustment
Old Apr 19, 2010 | 03:25 PM
myakkadodge's Avatar
If it is not the motor, check the wires in the rubber boot between body and door. they are known for breaking...
Old Apr 20, 2010 | 03:30 AM
The motor works great, I gave it power and the window went right up. I ohmed out the wire between the rear switch and the front switch and came up with .2 ohms, which stayed steady no matter how much wiggling I did. I'm going to be out of town for the next couple weeks so it's going to sit but I'll get on it when I get back.
Old Jun 10, 2010 | 12:31 AM
Felix's Avatar
I had the same problem, in my case the wires were broken in the boot.
Old Jun 10, 2010 | 10:20 AM
Scotty's Avatar
Top's Younger Twin
Thats what happened to mine...LR door went dead...five wires broken.
I got the entire harness for the rear door for 40.00 at the dealer...they had a few in stock so that should tell ya something.
stumpjumper
Sep 6, 2019 03:33 PM
micdazel
Feb 26, 2015 08:46 AM
Twodiesels
Oct 13, 2011 09:49 AM
steffan
Jan 9, 2007 09:24 AM
NoSparkplugs
Apr 8, 2006 12:14 AM
