auto driver's window wont roll up!
Old Oct 11, 2011 | 07:16 PM
Twodiesels's Avatar
Anyone give me some help on the window. It wont roll up. I am wondering if it's the switch itself or the motor. I took the panel off, and not sure which one it is. Which would be the first to go out? 2002 slt with 307,000.
Thanks!
Old Oct 11, 2011 | 08:10 PM
Silver R/T's Avatar
put power on motor and see if it works, if not then its your switch.
Old Oct 12, 2011 | 03:53 PM
Twodiesels's Avatar
Well I put power(12v) to the motor and all it does is hum. I am assuming the motor is bad.
Old Oct 12, 2011 | 04:47 PM
dsldan's Avatar
Seems to be one more common problems, usually 7-10 years if lucky.
Old Oct 12, 2011 | 07:02 PM
Silver R/T's Avatar
Time for a new motor, it shouldn't be too expensive, check ebay
Old Oct 13, 2011 | 09:49 AM
infidel's Avatar
Check if the track and linkages aren't binding before you spend any money.
I've found that if you push the window up while applying the switch that the window will often work fine again.
Sometimes they bind and just need a little help.
stumpjumper
Sep 6, 2019 03:33 PM
micdazel
Feb 26, 2015 08:46 AM
RWDCelicadude
Jun 10, 2010 10:20 AM
NoSparkplugs
Apr 8, 2006 12:14 AM
JW3
Dec 26, 2005 07:10 PM
