lower ball joint problems
Old Oct 18, 2009 | 03:57 PM
robwashu's Avatar
I just installed XRF lower ball joints and when I try to put the grease gun on the zerk fitting it will not fit because the zerk is to close to the lower axle ear. One side has the grease zerk facing backward and the other side is facing forward but toward the center and neither position works.
Has any one else had this problem? What orientation works?
Old Oct 18, 2009 | 08:07 PM
1985cucv's Avatar
did they come with a plug? i know sometimes you can grease them an then take the zerk out and put a plug in it so it will clear the axle my buddies 2nd gen was like that real dumb set up
Old Oct 18, 2009 | 08:45 PM
robwashu's Avatar
No. they come with a zerk that is about 3/4 of an inch long and is come out the edge of the ball joint almost horizontal. It look like the same design the moogs have.
How do you guys with moog ball joints grease them?
Old Oct 19, 2009 | 09:02 PM
robwashu's Avatar
Poeple with Moog joints which way did you face the grease zerk?
Old Oct 19, 2009 | 10:20 PM
slow2run's Avatar
you need to go back to xrf site
Old Oct 19, 2009 | 11:38 PM
WhiteMule's Avatar
Mine are pointed toward the front of the truck. I do not remember having any problem greasing them though.
Old Oct 20, 2009 | 08:35 AM
robwashu's Avatar
I called XRF and they were suprised to hear of the problem. I will try to install the grease zerks facing forward.
Old Oct 20, 2009 | 08:58 AM
Texan1983's Avatar
i have the same problem. what i did was unscrew it most of the way out or all the way put your grease gun on and push it in the hole and kinda screw it back and hold it in as you grease and it should pump in. grease as you need and pull it out (the zerk will usually come out with it) then screw the zerk back in. its a pain and shouldn't work that way, but thats what i had to do.
The other option i am thinking about doing is grind a little notch where the zerk is.
Old Oct 20, 2009 | 05:54 PM
robwashu's Avatar
It is good to know that I am not the only one with the issue. You think they would have designed out this problem.
Old Oct 20, 2009 | 06:48 PM
Texan1983's Avatar
i thought the same thing. think maybe something was off when they drilled/tapped the hole...
Old Oct 20, 2009 | 08:34 PM
Fisherguy's Avatar
I can just imagine the designers over at XRF right now, DOH!
Old Oct 20, 2009 | 08:44 PM
robwashu's Avatar
Are you guys using XRF or Moog? I called XRF and they said noone has had this complain yet, but they would pass it on to the engineers. If more people are having the problem we need to call them and let them know.
Hopper
13
Jul 4, 2008 06:20 PM
wcbcruzer
22
Apr 30, 2008 06:58 PM
96grndodge
Mar 11, 2007 02:24 PM
Diesel diehard
Feb 23, 2004 05:05 PM
stoneman
Feb 10, 2004 05:54 AM
