Lorenz Bilstein 5100 Suspension System Install Questions?
Old Sep 23, 2007 | 11:21 PM
Buffalo's Avatar
I have an '03, 3500 SRW, 4X4 with about 58,000 miles & the stock shocks. I've just ordered the above mentioned system & have a few install questions.
Awhile back, I read that you had to remove the front, top bolt on the trailing arm & loosen the front lower trailing arm bolt (with the guage on it) to drop the axle enough to get the new coil springs in.
When I ordered the system, Sean (@ Lorenz Ind.) said that all you had to do was remove one of the track bar bolts & the suspension would drop enough for the spring install.
What have you guys done? I'm not much of a mechanic but, like to try this stuff.
If you have any tips or suggestions regarding this install (including the rear mini-packs) I would really appreciate your help.
Do you recommend a front end alignment after the install?
Thanks.
Joe F.(Buffalo)
Old Sep 23, 2007 | 11:33 PM
ptgarcia's Avatar
Should be able to do it just by unbolting one end of the track bar. If that doesn't work you can remove one from the control arm also. But just start with the track bar.
When you're done align the front. You can do it yourself, its pretty easy to do. Set toe to neutral and leave castor alone. If you have trouble with death wobble add more castor.
Old Sep 24, 2007 | 10:43 PM
stumpjumper's Avatar
unbolt driver side of track bar and it should droop enough to install springs. also don't forget to unbolt 13mm bolt for the brack hose bracket and also the top nuts on the sway bar links..
Old Sep 25, 2007 | 12:21 AM
Buffalo's Avatar
Thanks for the advice!!!
Joe F.(Buffalo)
Old Sep 25, 2007 | 08:24 AM
paroxysym's Avatar
we just unbolted the trackbar and took the springs out that way. easy as can be.
mtnman006
24
Sep 8, 2009 03:14 PM
Chopper_Bob
57
Jan 29, 2009 01:49 PM
Bwest99svt
Feb 21, 2008 07:24 PM
Joe T
16
Jun 27, 2007 07:02 PM
SSweeney
Nov 22, 2006 12:27 PM
