Lights Dim & Get Bright When Truck is Started
Old Nov 25, 2005 | 11:50 AM
Mark Hodowanec's Avatar
When I start, the lights get dim for a couple of seconds then get bright. They do this several times. Initially, I thought that it was the intake heater grill kicking on and off, but they do this even when the engine is fully warmed up.
What gives?
Old Nov 25, 2005 | 11:56 AM
donhov's Avatar
Mine does the same to the point of actually seeing the lights slightly dim. I would guess that it is the grid heater's cycling on and off. If in doubt I would take it in to the dealer to have it checked. It should still be under warranty?
Old Nov 25, 2005 | 11:57 AM
John Faughn's Avatar
Some other load cycling on and off , like AC-defrost uses AC to help .
Old Nov 25, 2005 | 12:38 PM
STATELINE's Avatar
probably the intake grid heaters, if it's cold outside, I beleive they are triggered by outside ambient temp, not engine temp
Old Nov 25, 2005 | 12:41 PM
Geico266's Avatar
What gives?
It's normal guys. It's the grid heaters. They go on and off below 30 MPH when the air temp is below 50F. (I think) Engine temp has nothing to do with it. There is a way to run the power source through an poil pressure switch to shut it off when the engine is running if it bothers you. To me it is added wear and tear on the alternator, and grid heater relay that is not needed.
Old Nov 25, 2005 | 01:09 PM
Do you know how to do this? Can you post?
Thanks!
Old Nov 25, 2005 | 01:15 PM
Geico266's Avatar
Thanks!
https://www.dieseltruckresource.com/...ressure+switch
84mphcdt
Mar 31, 2009 03:45 PM
danalex
Dec 27, 2007 01:39 PM
Ramcam
Apr 7, 2007 03:43 PM
larry30000
Feb 26, 2006 06:29 PM
