lights
Old Aug 20, 2004 | 07:05 PM
sl0hburn's Avatar
lights
i need to get fog lamps and highbeams to turn on at the same time in my new 2004 dodge ram 2500 diesel.
Old Aug 20, 2004 | 08:09 PM
DPG's Avatar
DPG
Depending on where you live, you could get a ticket for that. In Michigan, it's illegal to have more than four lamps lit at a time. Each high beam light counts as two. Therefore, it's ok to have your low beams and your fogs lit at the same time, but you can't have your brights and your fogs lit at the same time: six lamps.
Old Aug 21, 2004 | 12:19 AM
SuperGewl's Avatar
That doesn't make a whole lot of since, because you can add Driving lights & according to what you just said then yo will still have 6 lights on at the same time
Old Aug 23, 2004 | 07:55 PM
DPG's Avatar
DPG
That's right. If you have driving lights AND your high beams on, you are technically illegal. I'm not saying everybody gets written, but it is not legal.
Old Aug 24, 2004 | 06:18 PM
Jmac's Avatar
Genosgarage.com should have a product your looking for expensive though. It's called a Brite Box. It might work. I would like to have it myself but it's too $$$$$
Jamie
Old Aug 24, 2004 | 08:15 PM
doug60's Avatar
If you jump the ground contact from the fog relay to the ground contact on the parking light relay, your fogs will go on with the parking lights . Do a search on fogs, you should find the pin location & pin numbers. I did it on mine
Old Aug 24, 2004 | 09:22 PM
Nevada's Avatar
I can make my fogs go on with the parking lights and my truck is pretty much bone stock. I have not jumped anything to anything, it just works.
Old Aug 24, 2004 | 09:35 PM
joel's Avatar
Why does each beam count as 2? It's just a different fillament in the single bulb, right? When you switch to high beams, the low fillament goes off, so you're still only running 2 bulbs there, right? Add in the fogs and you still have 4 lights burning as far as I can see....
Old Aug 24, 2004 | 11:09 PM
DPG's Avatar
DPG
I know that it's just one filament on highs, but the highbeams count as two lamps, probably because they are high beams.
cummins dsl
22
Jun 27, 2005 11:53 AM
MoreSmoke
22
Jan 10, 2005 03:05 AM
CHarlan
Aug 6, 2003 08:40 PM
