Infinity Amp Removal
Old Aug 17, 2009 | 08:36 AM
Huntsville 3500's Avatar
Anyone have good step by step instructions for removing the Infinity Factory Amp? Working on a 2003 QC 3500. All I really need to do is get to the speaker connector at the amp, disconnect it & tap into the wires for an aftermarket amp. I removed the glove box and man..its way up there. Before I start randomly removing dashboard screws, I'd like some input from someone who has accomplished this.
Thanks!
Old Aug 17, 2009 | 08:55 AM
enafzige's Avatar
Unless you have good reason to do otherwise, I'd access the wires coming out of the head unit. That part of the dash is alot easier to access.
The factory amp also has some funny crossover stuff incorporated into it, so it may be tricky to get a full signal output if you're looking for something coming out of the amp.
--Eric
Old Aug 17, 2009 | 09:20 AM
Maybe I wasn’t too clear in my posting about what I want my final outcome to be. I will use an aftermarket amp with an after market radio. I need to get to the speaker wires to connect them to the amp. The factory amp will not be used at all. I know it’s a bear to get to the factory amp so if I can just get to the harness where it plugs into the factory amp, I can get to the speaker wired from there. The wires at the radio access go thru the factory amp so they can not be utilized.
Thanks
Old Aug 17, 2009 | 01:37 PM
alMout's Avatar
You can get to the right side speaker wires behind the right side kick panel. You can get to the left ones either behind the left kick panel or at the harness above the parking brake pedal.
To remove the kick panels, open the door and remove the threashold trim. The panels will pull off after that.
Old Aug 17, 2009 | 06:27 PM
Mocho's Avatar
You just remove the glove box and you can remove the amp, it's a major pain in the butt but you can do it. I spent probably 20 mins just getting the 3 or 4 bolts out. Now I can drive over the stupid POS!
Old Aug 18, 2009 | 09:59 AM
Can anyone tell me the wire colors for the drivers side harness? As you can see in my other posting, I popped the drivers side seat belt air bag cartridge probing for wires.
CTD NUT
27
Apr 30, 2007 08:13 PM
vtailflyer
Jul 20, 2005 07:15 PM
chucktownsend5
Jan 19, 2005 11:22 AM
signature600
Sep 16, 2004 02:35 PM
vtailflyer
Jan 3, 2004 07:36 PM
