Ignition power
Old May 3, 2004 | 11:20 PM
westcoaster's Avatar
Ignition power
I have installed a battery in my truck box for my slide in camper. I have connected this to the front battery via 2 10ga wires. The positive wire goes through a starter selenoid I picked up at the local parts store. What I need now is a 12v source that is switched by the ignition (low current draw) to power the selenoid.
Where has everyone been pulling their "ignition on" power from? I have been eyeballing the fuse box under the hood but that looks like a chore to pull all apart just to find there is nowhere to connect anything to...
Old May 3, 2004 | 11:26 PM
Haulin_in_Dixie's Avatar
Re: Ignition power
Sorry, but the solonoid won't work. It will burn up quick. Have tried that a couple of times, they are made for short use. You will need a relay strong enough for the load.
Old May 3, 2004 | 11:50 PM
Re: Re: Ignition power
Hmmm... Must be a brand or a type of selonoid. I had one on the '93 that was used steady for seven years. Having said that, the selenoid went with the truck and I bought a diffrent type this time. Maybe I wont have the same luck...
Old May 4, 2004 | 09:38 AM
Ray Roton's Avatar
Cig. lighter is best place I have found.
Old May 4, 2004 | 11:13 AM
nickleinonen's Avatar
that works well, but it is also active in the accessory key position... i tapped that for my pyro gauge
Old May 4, 2004 | 01:47 PM
Under the hood, ADS relay output. (Automatic Shut Down)
corygale
15
Jul 9, 2010 04:43 PM
NJMurvin
Jan 14, 2010 07:59 PM
SnowRider1
Nov 25, 2009 02:35 PM
88xjwheeler
Jun 20, 2008 12:00 AM
5.9Excursion
Cummins Conversions
Mar 20, 2008 04:47 PM
