Ignition on no power/crank cluster lights/fuel pump
Old May 19, 2010 | 02:21 PM
corygale's Avatar
as it reads 2004 2500 diesel was parked for 3 weeks, went to start it turn ignition on and its as though it is still off door chime works and kms show but everything else is dead, cluster doesnt light up, fuel pump doesnt run , fan blower works , overhead compass doesnt, checked fuses all good, any suggestions also checked all the grounds i could find and acess all good????? not so happy today
thanks in advance
cory gale
Old May 20, 2010 | 06:15 AM
corygale's Avatar
No one else encounter this problem???
Old May 20, 2010 | 10:26 AM
bigwheels94's Avatar
Check all the battery connections, & battery condition. I've seen similar issues with bad connections.
Old May 20, 2010 | 02:05 PM
corygale's Avatar
cleaned them all and still the same is like there is a switch turned off no fuel pump nothing engaging is the a main wire with inline fuse or something i should be checking??
Old May 20, 2010 | 05:41 PM
corygale's Avatar
OK narrowed it to ignition, then unhooked the immobiliser and used a jumper wire and bang everything came on truck cranked but did not start so im thinkin it the immobilser locked up or malfunctioning and suggestions or do i just replace it ??? and if or why would this be set off and do its job . this truck is never locked , ever ??
anyone have any issues with these lil units before
thanks people
Old May 20, 2010 | 09:34 PM
bcfitzsimons's Avatar
Are you sure you batteries are charged up? The computer uses juice even when the truck is off, and after a month most batteries are totally discharged because of this parasitic current.
Old May 20, 2010 | 09:40 PM
corygale's Avatar
unplugged imobilizer used small jumper wire in the plg and she cranked over like crazy das lit up fuel pump running all was fine but just didnt start. so it has to be the immobilser just dont know why ??batteries are at 12 volts i charged them first when she wouldnt crank
thanks guys still confused as to what happen i parked the truck there she worked fine
Old May 20, 2010 | 11:41 PM
torquefan's Avatar
Some immobilizers interrupt more than one circuit on the vehicle. Is it possible that an ECM-related circuit is still being disabled and you need to add another jumper?
Old May 21, 2010 | 09:11 AM
corygale's Avatar
anyone know what one of these things cost or what may have caused it or is there an easy fix ???? hung high and dry here home for 2 weeks and gonna be under the hood , this after puttin new motor in , love the ctd but losin faith worst is layin her up so long i guess,
Old May 21, 2010 | 01:43 PM
corygale's Avatar
k so heres the deal, using a jumper in the imobiliser plug i get dash lit up fuel pump running but still no power to the dlc so i cannot read/scan for codes or clear them. This is really bugggin me i got a prettty expensive pile of scrap here now, so how do i find out why there is no power to the dlc ?? is this the work of the imobiliser as well the scanner doesnt get power and the ignition can be off and everytthing is still a go because of the jumper in the imobiliser plug. What can i do here guys dealership is 2 hrs way plus dont like them , or what they do any suggestions are welcome and appreciated , tried unhookin bats for an hour, charge is good in them, what am i missing all fuses and grounds are good far as i can tell, i do believe one of my tires are locked up a sticky abs or something wouldnt cause this would it ??
HELP PLEASE
Old May 23, 2010 | 11:14 AM
corygale's Avatar
anyone??
Old May 23, 2010 | 11:25 AM
Sounds like you need a shop manual. With that you could run power to the pins in the ecm to power, & wake it up, etc. & run codes. Otherwise, I'm afraid you're SOL. Sorry. I have the manuals for the cummins engines, but they aren't the same as the Dodge so I can't help more than that.
Old May 24, 2010 | 01:12 PM
corygale's Avatar
do my key have a chip in it ? how do i know? and could all this be caused by a bad key?? i only have the one key i got only one when i bought frome dealer?? or is there no chip in my key?? my truck is 04.5 or am i barking up the wrong tree here thanks in advance by the way great site.
cory gale
Old May 24, 2010 | 10:32 PM
Only the 07+ trucks have a chiped key as far as I know. My 04.5 definitly has no chip. Also, my friends 07 has the chip, & with an aftermarket key with no chip, the truck started, & runs for about 10sec., & dies.
Your issues could be caused by the ign. switch tho.
Old May 25, 2010 | 07:50 AM
corygale's Avatar
off to the *********** i guess im outa options thanks for all the input guys
