How To: Multifunction Switch Remove/Clean/Install
Old Nov 30, 2012 | 06:23 AM
  #31
06RAM2500's Avatar
I'll get a pic up of an entire unit (steering wheel removed), if that's alright?
Old Nov 30, 2012 | 08:23 AM
  #32
Shorts's Avatar
Absolutely, let's have a look.
Old Dec 1, 2012 | 02:58 PM
  #33
06RAM2500's Avatar
OK, I got a good look at one, and your right. All you need to do is remove those 2 screws and not the steering wheel. A brand new unit has the collar those two screws attach to making it look like you need to pull the steering wheel.
Old Dec 21, 2012 | 11:35 AM
  #34
k4jjm's Avatar
Thanks for the great write up and photos. I'm sure this will help many with their MFS problems... great job!
I also experienced problems with my MFS a while back. I did not remove & clean the switch... instead I re-seated the harness connection, pulled some slack from under the dash, then anchored the harness with zip ties under the dash to prevent future stress on the connection.
I've not had any MFS problems since... going on 2+ years now.
Thanks again!
John.
Old Mar 19, 2013 | 03:49 PM
  #35
LAPA's Avatar
Ok my question is (because i have someone telling me this is going to end up in a mess) Is there ANY chance that the air bag will go off when i pull the cover off and unplug and replug in the cable in?? Going to try what K4jjm did but this person is sure that ill blow the airbag up! THANKS
Old Mar 19, 2013 | 04:04 PM
  #36
k4jjm's Avatar
I had no issues with the air bag... and have had no multi-function switch problems since reseating the connector and relieving the tension on the connection.
The connectors I removed went to the MFS only... not anything else. There are other connectors within the column which I did not disconnect. I can't imagine disconnecting/reconnecting the airbag would cause it to engage.
Good luck!
John.
Old Mar 19, 2013 | 04:11 PM
  #37
LAPA's Avatar
THANKS!!! Ill un hook the batteries and then try your fix.
Old Nov 6, 2013 | 06:59 PM
  #38
Brboling's Avatar
Grateful!
I have been having the MFS problem for quite awhile now, as in years. Truck is an '06 with 136K on it. Well after reading this thread, I discovered the TSB and scheduled an appt with my local Dodge dealer in Auburn, WA: Tom Matson Dodge. Had my MSF replaced today and zero dollars out of pocket. Thanks DTR!
Old Nov 6, 2013 | 07:06 PM
  #39
Shorts's Avatar
Update, since performing this cleaning of the MFS and making this How To post I have had zero malfunctions since.
Recently we drove fro TX to S.FL during the weekend that Tropical Storm Karen was making landfall. We went through some sporadic downpours over the three day trip. I recall thinking I am glad my wipers work
Old Nov 30, 2013 | 03:08 PM
  #40
commtrd's Avatar
I bought a new MFS and it has the big ring collar deal on it. Does it just pull off?
Old Nov 30, 2013 | 03:10 PM
  #41
commtrd's Avatar
I tried it and the collar just pulled straight off.
Old Jan 6, 2014 | 09:26 PM
  #42
2kayaks's Avatar
MFS Recall
I have the 06. 5.9 litre. I had the MFS installed as a recall three months ago. I rarely use my truck in the winter in the Yukon but just a few days ago my wipers stopped working, then later in the day when the vehicle was warmed up they worked fine. This was the same thing three days in a row. The wipers would not work in the colder mornings but worked fine a couple of hours later when the vehicle was warm. Thought it might be the new MFS, so I brougt it in the dealer and everything worked fine and they are suggesting I need to replace the motor. Does not really make sense to me? Has anyone else had this problem? Suggestions? Would really appreciate the help. (2 kayaks).
Old Jan 7, 2014 | 07:29 AM
  #43
Shorts's Avatar
Pull it out and clean it, that's a basic troubleshoot. Perhaps there's too much di-electrc grease that it freezes over on the contacts and blocks the signal.
Old Jan 7, 2014 | 12:36 PM
  #44
2kayaks's Avatar
MFS Recall
Shorts, thanks for the very prompt reply. Should I disconnect the batteries prior to doing this. Fearing the air bag or having to reset something I know nothing about.
2kayaks
Old Jan 7, 2014 | 12:45 PM
  #45
Shorts's Avatar
2kayaks
You know, now that you ask me that I have no idea what I did on my batteries Best I can recall I probably left them hooked up. I remember being able to test the MFS really quick by reconnecting the harness.
Certainly if you feel more comfortable disconnecting the batteries, go ahead and do that. There'd be no harm doing that way.
