How difficult to replace the steering box? And other Q's
Old Nov 19, 2013 | 10:21 PM
RobG's Avatar
I ordered a rebuilt steering box from AutoZone recently, along with one of those steering braces (from another place). I started reading some other threads here and it sounds like I may want to return this AutoZone box and go for a 2008+ box. Is there a write-up someplace that has all the pieces I'll need if I do that? I just replaced all the tie rods in the front end a month or two ago, but I still get nasty death wobble. New tires, new steering damper, new tie rods. Nothing is curing it. I have new hubs to go on soon, and the steering box stuff. Truck has 95k miles on it.
Next Q... how hard is to to replace the box? At a quick glance it looks like it's bolted to the frame on the driver's side. Aside from that and disconnecting the steering shaft and the tie rod that connects to it (or whatever it's called), is that it? Oh and of course the fluid line from the pump.
Thanks!
Rob
Old Nov 20, 2013 | 01:37 PM
SOhappy's Avatar
Not that difficult, hardest part had something to do with the hoses & purging if I remember right.
I find these trucks pretty straight forward to work on for the most part compared to other vehicles I've owned. Especially with the wealth of knowledge & good folks on forums like these.
Old Nov 21, 2013 | 12:58 PM
trik396's Avatar
Just replaced mine with a Borgeson unit... much better than newer style as far as I am concerned. Wasn't too difficult.
Old Nov 21, 2013 | 01:41 PM
RobG's Avatar
Wow the Borgeson unit is $509! The AutoZone one was only $135. Is it really worth that much more?
Rob
Old Nov 21, 2013 | 02:56 PM
ColinP's Avatar
spend the extra $25 and get a decent pitman arm puller! it will be well worth it.
Old Nov 21, 2013 | 10:52 PM
trik396's Avatar
I paid less than that thru Amazon directly from Borgeson
You get what ya pay for. Better warranty too
The new mopar box is the same design only larger. I read an article from Borgeson and it convinced me their design is far superior. Plus it comes with new pitman arm. Borgeson has been doing steering for over 100 years.
Old Nov 22, 2013 | 08:38 AM
roughstock's Avatar
I bought my 03 and it had a new updated '08 steering box and pitman on it already. it steers great, for now. I didn't want to wear it out, so I ordered a steering brace to keep the stress off the new box.
However, depending on who's steering brace you have, it may take some minor mods. Let them know what truck you have and if you have the updated '08 box. it requires a larger nut on the shaft on the box, because the 08 has a larger sector shaft. it also sits out further from the frame, so I had to use a die grinder and elongate the holes in the brace to be able to slide it toward the passenger side to center the nut in the hole where the support bearing would go. Also depending on whos brace you get, you may need to shim the support bearing out away(down) from the box to get clearance from using the larger nut. Sorry I don't have picts. if you need more detailed help, I can try to explain it better.
My experience has been that aftermarket steering boxes, like from napa, autozone, etc are garbage. I went through 3, in a matter of 2 weeks, from napa before I just went and got a new one from Chrysler. that was on a dodge diesel at my work. I would suggest do the 08 upgrade and brace or the borgeson.
Old Nov 22, 2013 | 08:17 PM
BacktoBasics's Avatar
I went with a Cardone pump from Rockauto wasn't 100% satisfied if I still had the truck I would have replaced with the Borgeson the next time it failed.
VERY straight forward install, definitely get a good pitman arm puller , flush the system really well, and make sure you get all the air out of the system.
FWIW when I got wobble really bad it ended up being ball joints.
Old Nov 22, 2013 | 10:08 PM
RobG's Avatar
I found one on Amazon, but it's $485. And it sounds like I'll have to send back the brace I got too. Crap this is ridiculous.
If ball joints is gonna be the answer, I'll say to hell with the steering box for right now and figure out how to afford to replace the balljoints. Last estimate I got on that was enormous, and it's not something I can do myself.
The last alignment I got, the guy did say the balljoints were getting close to needing replacement.
Edit: Found a set of Moog ball joints on Amazon; roughly $50 ea (for each upper and each lower). Also added a pair of Precision u-joints at $42 ea, figuring maybe I should go ahead and have those done too. What should it cost to have somebody change this stuff out?? Without a press, it's just not something I can do. At least the hubs can be changed while they're at it, since I already have those.
Rob
Old Nov 23, 2013 | 07:07 AM
IF the press is all that is holding you back rent one from autozone or advance. The job is time consuming and can be hell on the hands but I had it done in two days including waiting for parts the first day.
For less than the price of paying a dealer to install crappy joints, I did XRF ball joints, new u joints, hubs, brakes, and the reman steering box.
Old Nov 24, 2013 | 05:30 PM
trik396's Avatar
I would not use Moog for this application
Old Nov 24, 2013 | 10:53 PM
RobG's Avatar
So are XRF's the way to go? Found a set of them on eBay for $250 for all four.
Rob
Old Nov 25, 2013 | 11:28 AM
trik396's Avatar
I used McQuay Norris joints and all is well. XRF is another good choice
Old Nov 25, 2013 | 12:53 PM
railroaderone's Avatar
Or if you can afford them the Carli joints are the top of the line. But I believe forthwith price they must be made of gold.
03CTDCO
Jul 28, 2011 09:17 PM
89dieselkong
Nov 21, 2010 10:06 AM
EverydayDiesel
41
Jan 17, 2008 11:49 PM
WACTD
13
Feb 2, 2007 11:51 PM
CRSmith
Mar 16, 2006 09:28 AM
