How to: Check codes, test gauges, and check hours
Old May 26, 2009 | 09:45 PM
  #31
Clane's Avatar
Originally Posted by rip 112
Bump..........
No need to bump, it's a sticky... Just gotta be patient....
Old May 28, 2009 | 08:57 AM
  #32
rip 112's Avatar
Should I still be patient? I wanna know whats going on and what my codes mean.
Old May 28, 2009 | 09:45 AM
  #33
madhat's Avatar
Administrator/Jarhead
I would suggest making a new thread on this with the codes that you are showing as the thread starter...
Just my .02, since I don't have the answer for you.
Old May 28, 2009 | 03:49 PM
  #34
Clane's Avatar
Talking
That or take it to the dealer ....
Old May 28, 2009 | 05:23 PM
  #35
rip 112's Avatar
Nah, I'll pass. Truck runs fine, must not be that important, was just curious.
Old Jun 4, 2009 | 02:59 PM
  #36
Rednax's Avatar
Originally Posted by madhat
How to Check codes:
Turn the key on and off 3 times, do not engage starter. On the third cycle, leave the key on. In my vid, it reads 'DONE' because I have no codes, but if you have them, they will display.
How to do a gauge check/display 'C' codes:
Press the odometer trip reset, hold it, then turn the key to the 'ON' position. Do not engage starter. Once the gauge check starts, you can release the button. Once it is done with the gauge check, it will display 'C' codes.
Hour meter check:
Turn key to 'ON'. Press and hold Odometer trip reset button. After a few seconds of it being pressed, it will show the hours.
hth...
mad
First, I want to say thank you for the trouble in posting this information. I used the following link to help decipher P-codes:
P-Codes:
http://www.cumminsforum.com/forum/3r...en-trucks.html
I had no "P" codes, but did have a "C" code combination"
A4 01
I haven't found A4, so if someone would post, it would be appreciated.
(I see that the OP is deployed at Iwakuni; I've a son at Kadena (VMGR 152). I was thinking of ALL of you-all while at the recent annual air show at NAS Corpus Christi; how is that May 5 show?)
Old Jun 6, 2009 | 07:32 PM
  #37
2fastfountain's Avatar
Just did my 03 pretty cool. It brought up code p0483 which is fan speed whatever that has to do with anything doesnt overheat.
Old Jun 6, 2009 | 09:59 PM
  #38
madhat's Avatar
A big thing with these codes... if anything out of the norm is detected by the ECM/PCM, it set's a code. Sometimes, there is just a hiccup, and something goes out of tolerance for a second, then straightens back up.
If the truck is not running bad, or you don't see any symptoms that the code described, get it cleared and see if it comes back. Make sure it's a failure, an not just a glitch.
Rednax, I'm in Okie right now, just a stones throw away from Kadena. Small world...
Old Dec 18, 2009 | 11:11 AM
  #39
MyFirstRide's Avatar
codes
so i checked my truck and i have some codes, where do i go to figure out what they are and how to clear them?
Old Dec 18, 2009 | 05:29 PM
  #40
madhat's Avatar
http://wiki.dieseltruckresource.com/wiki/Computer_codes
Here are the codes... What are they?
If you do not have a programmer like a smarty that will clear codes, you can take it to an auto parts store, and they can clear them out for you.
Old May 6, 2010 | 11:37 PM
  #41
Zeppe807's Avatar
Hello,
I just checked my gauges and the speedo only goes to 100 not 120...
Is this bad?
Old May 7, 2010 | 11:59 AM
  #42
madhat's Avatar
What year truck?
And, yes, I think that means that there is something wrong with the computer... do you have a programmer with a speed limiter on it?
Old May 7, 2010 | 09:41 PM
  #43
Zeppe807's Avatar
What year truck?
Not to get off topic, I will PM you.
2006 2500
Old May 31, 2010 | 08:09 AM
  #44
hfhanson's Avatar
Hello, I am new to the forum, this is my first diesel truck, the first ouner had some sort of chip on it, I have none on it yet. I did the P code check and the C code check and came up with P0234, P0839, C codes was 00 00. In the list of codes the P0234 is Turbocharger Over-boost Condition, not sure what is causing that, the P0839 is not in the list of P codes, Can any one help me out with this? Thank you.
Old May 31, 2010 | 09:44 AM
  #45
madhat's Avatar
Welcome to the DTR. You're from my old neck of the woods, I grew up in Okeechobee.
The overboost code means that the ECM saw over 42-ish PSI of boost, and set that code. Nothing is wrong because of that, that code won't hurt anything. However, if the stock turbo saw that a lot, it could mean that your truck was beat on, and anything over 40 psi is not good for a stock turbo.
BTW... It's spelled Cummins... don't know if spell check got your sig or what.
Let me know if you need anything.
mad
