How to: Block heater cord install
Great install description. I would only add that an auto-eject receptacle will prevent the embarassment of dragging an A.C. cord down the road with you when you forget to unplug first.
Kussmaul makes a good one that most of the fire apparatus mfg's install.
Here's a link if you're interested
http://www.kussmaul.com/091-55-20-120.html
Administrator/Jarhead
No WTS light... It gets cold here, too! Thanks, buddy! You need to update your sig...
I hope it works on the 6.7...
Hey Mad its funny you mention North Charleston because the company I work for has a new plant there right by the airport where we build fuselage sections for the new 787. I had to travel out there a few times to get the new facility up and running. If I am ever out there again we will have to get together so I can see that truck of yours.
Very good post. Mine came with the plug installed but it does not work!! (no slight noise when plugged in and no heat). Now, thanks to your pics, I think its because they didnt get the connection in far enough. The anti seize cant hurt.
My truck ain't nothin special...
Hope it works out for ya... I was
when I was trying to take that plastic cap off, and that dang thing would not come off!! Took me about 20 minutes with some vice grips to get it off...
I installed my cord today. I used the Mopar cord, it has a straight connection instead of the angled connection shown in the pictures. It was about the easiest thing I've ever put on my truck.
I took the intake tube off and had to use channel locks to start turning the cap on the heater. After that it came off easily. Putting everything back on was straightforward. The mopar cord has those little pop in tabs that snap in holes on the frame.
I put anti seize on the lock ring and put electrical antioxidant on the electrical connection. I just put a little on the end of a toothpick and stuck it down in the holes.
At first I thought that the mopar one with a straight connector would rub against the intake, it doesnt. My block heaters electrical connections were not nice and level like Madhats and were vertical. In this situation the straight connector made things go in a little easier. The angled one would have been pointed toward the back of the truck with mine.
Thanks for the post!!! Just bought an 04 in Arizona, and it didn't have the cord, so I just assumed it being a southern truck, didn't have a block heater. Did a search and within a couple of minutes learned that all the 5.9's come with the heater, just not all with the cord. Now I know where and how to install it. You guys just saved me alot time and $$$. This site is great.
Did mine yesterday. Thanks Geno's. We're suppose to have freezing rain tonight so it will be a blessing. I routed my plug up the the center of the front bumper. Seemed to be a tray like shape back there for the cord to lay into niceley. Zip tied it so if it fell it won't drag the road.
