Help trace down vacuum leak
Old Oct 18, 2009 | 11:28 AM
ROCKHEAD's Avatar
I have a 2004.5 that the vacuum pump started running almost continuously. I tried checking the hoses for leaks, but am having trouble finding anything. If I kink the hose in the soft rubber area the pump turns off. Are there any areas that are more likely to leak than others? I took off the zip ties, but the hose looks good underneath. I cant tell if I can feel a leak under the pump or not.....
Old Oct 18, 2009 | 01:47 PM
tryNto's Avatar
If you bend the hose and the pump stops, that means there is no leak @ that point to the pump... Try bending the hose a little farther along, away from the pump, till you find it doesn't stop the pump anymore, your leak is between this bend and the previous 1...
Old Oct 18, 2009 | 02:01 PM
MikeyT's Avatar
Had the same problem - shop actually figured the diaphram in the pump was leaking and replaced that with no results. Turned out to be leaking from a rub in the small diameter soft line.
I didn't find the actual leak until we pulled the whole line out and replaced it with tougher stuff.
Old Oct 18, 2009 | 02:31 PM
ROCKHEAD's Avatar
At the "T" right after the pump.
Plug one side no change
Plug the other side no change
Plug both, pump turns off.....
Old Oct 18, 2009 | 03:17 PM
MikeyT's Avatar
That doesn't make a lot of sense. Either the 'T' fitting itself is leaking or you've got more than one leak.
Foxborough
Sep 13, 2007 10:09 PM
Sask
Aug 5, 2006 12:59 PM
wexman
Jan 1, 2005 10:02 AM
Jun 15, 2003 02:10 AM
Jim O
Oct 29, 2002 08:23 AM
