help with power window
Old Oct 13, 2010 | 06:33 AM
farmer b's Avatar
My passenger front window went up and wouldn't come down. I replaced the motor and regulator which left it half open after install. turned key on and window wouldn't closer from driver side. Went to passenger side and window went up but won't come down. when I hit the switch I can hear motor activate to go up but hear nothing when pressed to go down. ANY ideas? I appreciate any help from you guys and gals
Old Oct 13, 2010 | 06:54 AM
Hodge's Avatar
Mine has started acting up a little, and it appears to be an issue in the drivers side switch. You might want to look at them. Replacement switches don't appear to be too expensive- $37 on Ebay, for my 94.
Old Oct 13, 2010 | 07:14 AM
farmer b's Avatar
Thanks does the power run through that first before going to the other switches? just curious since it wouldn't do anything, but the passenger side switch successfully rolled it up. Thanks for the idea electrical wiring is not a favorite problem of mine to have!
Old Oct 16, 2010 | 11:45 AM
amesff01's Avatar
The wire looms that run from the body to the door are also prone to cracking, and breaking wires. Might want to check those. Texan1983 had that happen to him.
Crossy's son
Aug 18, 2011 07:28 AM
mbaker
Jun 6, 2011 12:32 AM
Rednecktastic
Aug 29, 2010 11:26 PM
oneslowyfz
Feb 11, 2008 08:21 AM
raven392003
Oct 29, 2007 11:39 AM
