Grid heater question
Old Feb 27, 2005 | 11:45 AM
Usta HaveA Hemi's Avatar
Question Grid heater question
What is it? I hear about letting it cyle before driveing. I think that is why my lights dim and I hear the heater fan go up and down. Please explain.
Thanks! Usta
Old Feb 27, 2005 | 12:38 PM
eswartz's Avatar
The grid heater is located in the intake and heats the intake air before going into the cylinders for easier/better combustion. When the outside temperature is colder, the grid heater stays on longer. The indicator for the grid heater is located down and to the left of the BRAKE light that comes on when you first turn on you key. It will stay on longer when the temp. is colder, this is the grid heater heating the intake air. After the grid heater indicator (sometimes referred to as a "Wait to Start" light) goes out and you start your truck, the grid heater still cycles as needed to heat the intake air, this will dim your lights as the heater puts quite a load on your electrical system, I forget how much, maybe someone else can chime in on that. The grid heater will continue to cycle even as you drive for a little bit.
Hope this is correct and helps you out a little bit.
That's my .02 on the grid heater.
Eric
Old Feb 27, 2005 | 02:15 PM
Tony T.'s Avatar
Smile
I believe the grids are pulling somewhere in the neighborhood of 90+amps. They are located drivers side of engine right under the intake horn (the horn that the oil dipstick is attached to).
Tony
Old Feb 27, 2005 | 06:35 PM
redneckonthenet's Avatar
It is a toaster for the intake!
Old Feb 28, 2005 | 08:39 PM
SuperGewl's Avatar
The grid heaters will cycle for 3 minutes after startup according to the owners manual.
Read the Startup info on the visor, it will enlighten you
Old Feb 28, 2005 | 08:54 PM
Fronty Owner's Avatar
Where do I put my poptarts?
SpeedyWS6
15
Feb 2, 2011 07:22 PM
Ramrod90
Feb 3, 2009 07:39 AM
taildragger
Dec 4, 2006 10:00 AM
willieboy
Nov 8, 2006 05:44 PM
boiler-rat
Dec 17, 2004 05:35 PM
