Fuel Fill
Old Mar 18, 2007 | 04:41 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Question Fuel Fill
About to trade for 2007.....did they fix slow fuel fill? My 2003 takes forever to top it off
Old Mar 18, 2007 | 05:57 PM
HorseHauler's Avatar
Highly doubt it, still probably have to go with the fuel vent mod...
Old Mar 18, 2007 | 06:30 PM
djbikeman's Avatar
If you're buying the 5.9l 2007, the answer is no.
Old Mar 18, 2007 | 08:03 PM
Hairy1's Avatar
You mean they have not corrected the venting problem?
Old Mar 18, 2007 | 08:07 PM
lol isn't that what you already asked
Old Mar 18, 2007 | 08:52 PM
djbikeman's Avatar
No...again. I mean it this time. Don't make me come back there. I'll pull over this truck right now. I mean no!
Old Mar 18, 2007 | 08:59 PM
dodge2005's Avatar
Cool
The vent mod is very easy to install and corrects all the fill CLICK fill CLICK fill CLICK fill CLICK problem just fill and go. It is a very cool mod.
Old Mar 18, 2007 | 11:18 PM
vegashd's Avatar
what exactly is the mod?
Old Mar 19, 2007 | 02:04 AM
annabelle's Avatar
Locate vent to higher spot on tank. Must drop tank, but is great mod. Adds about 5 gallons to capacity.
Old Mar 19, 2007 | 03:09 AM
TexasCTD's Avatar
http://www.glacierdieselpower.com/gdept.asp?dept_id=02
http://www.innertruck.com/store-cate...s_2429930.html
I recently did the vent tank mod to my fuel tank. It's not difficult to do once you drop the fuel tank. Basically it allows you to use the space in the fuel tank that is already there but is put in place for gasser Dodge trucks for fuel expansion. You cap off the stock location and drill the tank at a higher point for a new bunkhead fitting and route a hose back to the filler neck vent. You can then fill your truck up to the filler neck very easily and it adds about 5 gallons or so to the useable fuel space.
While you are doing that mod you might as well run some fuel hose from the plastic barbed fittings that are on top of the tank as well. I routed them up above the filler neck and looped them over and back down with a cheapo fuel filter on the hose to make sure no crud can get in the fuel tank.
Here is a link to another thread with more info on that one....https://www.dieseltruckresource.com/...d.php?t=117209
Hope that helps.
Old Mar 19, 2007 | 10:16 AM
wreedCTD's Avatar
my 06 has NO problems filling up.
Old Mar 19, 2007 | 10:45 AM
butchb's Avatar
Then yours is the only one I have ever heard of that didn't. Wow consider your self lucky!
Old Mar 19, 2007 | 10:48 AM
wreedCTD's Avatar
i guess i dont know the problem. i can fill about 15 gals in a min or two. i remember having to hold the nozzle at one pump, but the pumps i always fill up at i have had NO problems.
i think it is the pumps not the truck.
i have noticed i have some sort of vent if you look down the filler neck. i dunno what it is though.
Old Mar 19, 2007 | 10:58 AM
annabelle's Avatar
If you can only get 35 gallons easily and it takes you 10min. or longer to fill the last 5. I get 40 gallons very quickly with no clicking off.
Old Mar 19, 2007 | 11:04 AM
Truckman0097's Avatar
I have a 35 gallon tank and regularly fill approximately 32 gallons - takes about 5 minutes, no vent mod. Should I consider a vent mod? I was under the impression that this was fixed on the 07 Models, but this thread seems to state otherwise?
