Fuel Fill
Old Mar 19, 2007 | 12:18 PM
vegashd's Avatar
Well my question is this
if we only have a 34 gallon tank when I fill up i can get 32 gallons or so.
With the tank mod your telling me I will get 40 gallons?
If that is the case then if I only put 32 gallons in then no, it has yet to be fixed.
Old Mar 19, 2007 | 12:31 PM
chromegrill's Avatar
exactly...
Old Mar 19, 2007 | 12:43 PM
TexasCTD's Avatar
If it has been corrected you can fill the diesel up to the rim and see it in the filler neck with no effort at all.
I think the amount it can add varies a little from truck to truck. But it should add about 4 to 5 gallons of extra capacity.
Old Mar 19, 2007 | 07:17 PM
djbikeman's Avatar
I just ran mine down to the wrong side of the E red line today. it was 32 gallons to the first click. I don't have 20 minutes to waste clicking in another 5 gallons, so I left it. If you look at the fuel tank on the 07, the vent is in the same place it has always been. When it is moved up to the highest point (fuel tank vent mod), you get the extra capacity. I have done it on my last 2 CTD's and will probably do it on this one as well.
As stated before, when you install the vent mod, you will be able to fill it to the filler neck taking advantage of the full volume. Another nice feature of the vent mod is that the fuel guage stays above full for over 100 miles due to the extra fuel capacity.
Old Mar 20, 2007 | 12:04 PM
BigRedMega's Avatar
No problem with mine. Full blast till its full.
Old Mar 20, 2007 | 12:15 PM
Oliverpuller's Avatar
I also have no prob filling up. As a matter of fact from a previous FORD PSD owner... I was impressed the first time I filled up.
Old Mar 20, 2007 | 12:53 PM
wade234's Avatar
Fill
I can't afford to let mine go below 1/2 a tank so it does not take long to fill. $2.60 a gallon.
Old Mar 20, 2007 | 05:03 PM
annabelle's Avatar
A 35 gallon tank will hold about 40 gal. when vent kit is added.
Old Mar 20, 2007 | 05:23 PM
Hounddog's Avatar
Mine fills just fine.When it clicks off,round it to the nearest dollar and move on.
Old Mar 20, 2007 | 06:44 PM
rjm022's Avatar
vent tank mod equals faster fill ups and more fuel in the tank!
Old Mar 20, 2007 | 07:00 PM
Hounddog's Avatar
Mine fills with the nozzel wide open just fine and if I wanted more fuel I add another tank.By the time I need more fuel I'm ready the get out of the truck and move around.Another few gallons is a big so what.
Old Mar 20, 2007 | 10:32 PM
djbikeman's Avatar
They all fill just fine, even with the big truck pumps, until the first click, but that wasn't the original question. He was asking about topping it off. If you want to see fuel at the filler neck, then it takes 20 minutes of click...click...click...click. With the vent mod, you can add an extra 5 gallons of fuel without the top-off time. You can see the fuel in the filler neck.
Personally, I agree. There's no way I'm standing at a fuel pump for twenty minutes squeezing an extra 5 gallons. The mod is a timesaver though, because it saves me trips to the truck stop. I average 3 fills a week, so it saved me 2 stops a month on my last 2 trucks with the extra capacity.
Old Mar 20, 2007 | 11:11 PM
RocketJohn's Avatar
From what I've gathered is that you can fill your tank to 34 gallons... if you want to push the limits past what the engineers of the truck determined to be capacity for that tank, then you can spend $40 and a few hours and jerry rig your tank so it can hold a few more gallons...
seems like a huge hassle to be able to drive 550 vs 500 miles on a tank, if you only fill up a few times a month, like me...
Old Mar 21, 2007 | 12:15 AM
TexasCTD's Avatar
The "engineers" that determined the capacity for the tank were designing it for gassers....not diesel. Dodge just didn't want to change it if it is saving them money.
It is definately an optional type thing if you want to do it. But, I like having an extra almost 100 miles of cruising range and knowing im filling my tank up to the rim...(same amount each time for calculating mileage).
To me it was worth it to pull the tank and look around in it and see how they designed it. Also to do this mod to it too....https://www.dieseltruckresource.com/...d.php?t=117209
If you have an 05 or later truck with an in-tank fuel pump you will probably have to pull the tank anyway if you plan to upgrade to an aftermarket fuel pump. These mods might as well be done then while it's down.
Old Mar 21, 2007 | 09:34 PM
Hairy1's Avatar
From: Adirondacks of New York and Daytona Beach FL.
Will no for myself soon --picking up 2007 in a couple of days
Thanks
