Frustrated with a vibration.. and a dealership
Old Nov 11, 2010 | 08:31 AM
  #31
mq105's Avatar
Originally Posted by Dieseljunkie
Just an update... I took the truck to a DIFFERENT dealer... Told them of the situation at the first dealer, and the service person laughed LOL... Got a call from them today, they are replacing ALL the U joints in the rear driveshaft as well as the carrier bearing under warranty... I will keep you posted if this was the problem, but something tells me, the vibes will be gone.
Scott
Either the second dealer is just good, or they are going above and beyond to demonstrate their superiority to the first dealer you mentioned. Probably a little of both; some competition tends to up one's game.
If this solves the problem, I would want to know why you keep having u-joints and carrier bearings fail at your mileage.
Old Nov 11, 2010 | 06:58 PM
  #32
PoorMansCat's Avatar
good to hear.... If they get your truck fixed, you might need to drop a box of donuts by the servie department for the techs and S.A....
Greasing the wheels usually goes a long ways..
Old Nov 18, 2010 | 11:32 PM
  #33
Dieseljunkie's Avatar
I never had a U joint fail, up to this point. I had a carrier bearing fail once.. and it was replaced under warranty, then I had the u joints fail, which caused vibration, which in turn tore the rubber on the carrier bearing, again.. so it was all replaced.
If it fails again, it will likely do it when I am out of warranty, so then I will be on my own. I am still amazed that the first dealer told me I needed an entire driveshaft...
Scott
Old Nov 18, 2010 | 11:36 PM
  #34
If the vibes come back, I'll be going one piece.. I just wanted to get it repaired again under warranty, since that's what I paid extra for when I bought the 7 yr 70k mile warranty. The problem I am seeing in my research, is that the one piece driveline is based on the automatic trans trucks, and the NV5600 trans does not have a one piece shaft that fits without modifications. I could be wrong though..
Scott
canadianskye
Oct 20, 2010 06:42 PM
roughstock
Apr 28, 2008 12:31 AM
tradin1
14
Jan 27, 2006 08:46 PM
G1625S
Jan 2, 2005 08:19 PM
VPI
Dec 12, 2004 10:02 PM
