Front end vibration needed helppppp
Old Mar 16, 2016 | 07:25 PM
terp393's Avatar
i Have a 2005 2500 cummins with a 6 inch fabtech lift the vibration was there before i did the work to the front end, I did upper and lower ball joints on both sides and all new tire rod ends and a passenger side u joint and took it to get aligned. drove it still had the vibration, i rotated the tires and still the same thing, the truck drives straight and dose not pull to the left or right, The vibration occures at 50mph and continues form there on out getting a little worse at 60 but not much, I have to do shocks at all 4 corners this weekend there pretty much shot and leaking like a siv, not sure if they would cause a print end vibration or not other then getting the tires re balanced I'm at a loss any suggestions would be helpful
thanks
Old Mar 16, 2016 | 08:31 PM
terp393's Avatar
Also the the tuck carries around 2000+ pounds at all times because its a welding rich i will be installing helper bags next week to help with the weight and to bring the *** end of the truck back up to where its suppose to be it sags about 1 1/2 -2 inches in the rear due to the weight
Old Mar 16, 2016 | 10:43 PM
ftltmp's Avatar
I am taking a stab in the dark, and say that the shocks very well could cause a vibration,with the shocks as bad as you say they are then the spring has nothing to control rebound of the springs. Thats where I would look at. Good luck
Old Mar 16, 2016 | 11:24 PM
Jeff in TD's Avatar
Shocks can cause vibration and cupping.
Since you know the shocks are shot, sensible thing to do would be change them and see if you still have the problem.
Old Mar 17, 2016 | 04:52 AM
terp393's Avatar
true there getting changed this weekend i have some bilstein 5100s that are going on
Old Mar 17, 2016 | 05:53 AM
terp393's Avatar
whell i just figured out the cause of the vibration the drive shat u joint blew apart going down the highway i crawled under the truck to find tranny fluid pouring out and a nice crack on the tail of the transmission
Old Mar 17, 2016 | 10:08 AM
steelblitzkrieg's Avatar
DTR Detective
Sorry to hear. I was going to guess driveline vibration due to possible excessive pinion angle. But I was guessing it was from the front shaft.
Old Mar 17, 2016 | 11:30 AM
Jeff in TD's Avatar
Yeah sorry to hear that. When I've lost a rear u joint, I generally feel it first at very low speeds, so I wouldn't have guessed that was your issue.
Gordonville
Apr 18, 2005 09:45 AM
oregon ram
Jul 21, 2004 06:11 PM
BigBlue
May 11, 2004 04:59 PM
Commatoze
Nov 21, 2003 07:55 PM
bcb1962
Jun 24, 2003 10:16 PM
