Front end suspension making "c lunking" noises when turning some times more than othe
Old Jul 19, 2004 | 05:33 PM
cquestad's Avatar
Maybe the joints? I don't know...you can king of feel it through the steering wheel.
Old Jul 20, 2004 | 02:36 AM
localnet's Avatar
cquestad,
I'll try to remember to call Gerad this am. I had the same problem this winter. When the weather broke, it went away. Me and a friend goofed around in 20 degree weather trying to figure out where the "clunk" was comming from. Never figured it out. And my friend/neighbor, is a machinest/engineer/mechanic/miracle worker.
I'll post as soon as I get with Gerad.
Mike
Old Jul 20, 2004 | 09:34 AM
cquestad's Avatar
Thanks localnet!
Old Aug 2, 2004 | 03:53 PM
cquestad's Avatar
bump...any updates or jogged memories?
Old Aug 2, 2004 | 07:21 PM
JohnnyH's Avatar
I dont know if this applies to anyone but I'll throw it out there. I also developed a noise I couldnt put my finger on. I took it to the dealer and they said it sounds like it was coming from where my running board attached to the body mount. He said a lot of running boards that attach to both the body mount and the rocker panel will make a noise. He put a pry bar on the board and moved it foward about a 1/4 inch and the noise disspeared.
The funny thing is the boards were on there for about 2 weeks before the noise developed. I guess once they settled in the brackets started rubbing.
Just something to look at if all else fails.
John
Old Aug 3, 2004 | 10:04 AM
shakycummins's Avatar
It's the trackbar mine did the same after installing my 2 in lift. I had to loosen and retighten the snot out of it. I found this after many hours under the truck.
Old Aug 13, 2004 | 11:30 AM
cquestad's Avatar
bump again...any updates or jogged memories?
Old Aug 14, 2004 | 09:02 PM
Mixer Man's Avatar
I just climbed under my new dually ,checking fluids and such and greased the tie rod ends . There was NO grease at all in there ,some watery crap came out but no grease . Took 6 pumps on the gun to see any at all come out of the bushing . Worth a try .
Old Aug 14, 2004 | 11:56 PM
Matt400's Avatar
Re: Front end suspension making "c lunking" noises when turning some times more than othe
Originally posted by Sux 2B urTurbo
Anybody wana take a shot at it ???
Trac Bar, had a fella stop by the other day with an 04 4x4 with a pop/clunk and found the trac bar bolt at the frame mount was loose.
It needs to be SUPER tight especially if it has been walking around.
The_Head
Jan 27, 2009 09:01 PM
NoSparkplugs
Dec 7, 2006 09:57 PM
Dojman
Dec 17, 2005 12:25 AM
NoSparkplugs
Oct 8, 2005 07:50 AM
ramlovingvet
Feb 23, 2005 09:26 AM
