flushes required?
flushes required?
its amazing on how many shops try and sell the customers flushes.
ie.. power steering, brake, tranny, diff etc. Don't fall for the hype. only required when there has been a failure OR your coolant has past its life cycle then a flush is required.
This bulletin is supplied as technical information only and is not an authorization for repair. No part of this publication may be reproduced, stored in a retrieval system,
or transmitted, in any form or by any means, electronic, mechanical, photocopying, or otherwise, without written permission of DaimlerChrysler Corporation.
THIS BULLETIN SUPERSEDES TECHNICAL SERVICE BULLETIN 26-003-07, DATED
MARCH 30, 2007, WHICH SHOULD BE REMOVED FROM YOUR FILES. THIS IS A
COMPLETE REVISION AND NO ASTERISKS HAVE BEEN USED TO HIGHLIGHT
REVISIONS.
SUBJECT:
Fluid Flushing Requirements
MODELS:
2005 - 2008 (CS) Pacifica
2006 - 2009 (D1) Ram Truck (3500 Pick Up)
2010 (D2) Ram Truck (3500 Pick Up)
2007 - 2010 (DC) Ram Truck (3500 Chassis Cab)
2005 - 2009 (DH) Ram Truck (1500/2500 Pick Up)
2010 (DJ) Ram Truck (2500 Pick Up)
2005 - 2008 (DR) Ram Truck (1500 / 2500 Pick Up)
2009 - 2010 (DS) Ram Truck (1500)
2005 - 2009 (HB) Durango
2007 - 2009 (HG) Aspen
2009 - 2010 (JC) Journey
2007 - 2010 (JK) Wrangler
2005- 2006 (JR) Sebring Sedan & Convertible/Stratus Sedan
2007 - 2010 (JS) Avenger/Sebring
2008 - 2010 (KK) Liberty
2007 - 2010 (KA) Nitro
2005 - 2007 (KJ) Liberty
2009 - 2010 (LC) Challenger
2005 - 2010 (LE) 300C/300C Touring (International Markets)
2005 - 2010 (LX) 300/Magnum/Charger
2007 - 2010 (MK) Compass/Patriot
2005 - 2010 (ND) Dakota
NUMBER: 26-001-09
GROUP: Miscellaneous
DATE: September 24, 2009
2005 - 2006 (PL) Neon
2007 - 2010 (PM) Caliber
2005 - 2010 (PT) Chrysler PT Cruiser
2005 - 2007 (RG) Chrysler Voyager (International Markets)
2005 - 2007 (RS) Town & Country/Caravan/Voyager
2009 - 2010 (RT) Town & Country/Grand Caravan
2005 - 2006 (TJ) Wrangler
2005 - 2006 (VA) Sprinter
2007 - 2010 (VB) Sprinter
2005 - 2010 (WH) Grand Cherokee (International Markets)
2005 - 2010 (WK) Grand Cherokee
2006 - 2010 (XH) Commander (International Markets)
2006 - 2010 (XK) Commander
2005 - 2010 (ZB) Viper
2005 - 2007 (ZH) Crossfire
DISCUSSION:
Chrysler Group vehicle fluid systems do NOT require regular flushing. These systems
include: engine oil, transmission oil, axle lube, brake fluid, power steering fluid, and
refrigerant. The only exception to this requirement are published in the vehicle
maintenance schedules, e.g. engine coolant.
Exceptions to this recommendation include only those instances where a failure has
occurred and/or the system has become compromised, contaminated or overheated
beyond the normal operating range.Chrysler Group does NOT recommend aftermarket chemicals to flush the engine,
transmission, brake or steering systems. Chemicals contained in these products can
damage the system elastomeric components, and contaminate the component fluid,
leading to loss of system/component durability and service life. When necessary, only the
original approved system fluid should be used to flush these components using teamPSEŽ
approved equipment.
If the engine coolant contains a considerable amount of sediment, clean and flush with
Mopar Cooling System Flush, p/n 04856977, or equivalent. Follow with a thorough rinsing
to remove all deposits and chemicals. Refill with a minimum of a 50% mixture of the
specified coolant and distilled water.
REVISIONS.
SUBJECT:
MODELS:
NUMBER: 26-001-09
DISCUSSION:
approved equipment.
vander
Jun 11, 2010 05:14 PM
Big Rig
19
Oct 21, 2004 09:24 PM
Mcmopar
Mar 8, 2004 09:08 PM
69D100
Feb 25, 2004 04:11 PM
phox_mulder
Feb 28, 2003 10:32 PM
