First time I've noticed...
Old Jan 8, 2007 | 07:11 PM
mitternocht's Avatar
Don’t forget here in the US where we drive on the right hand ride of the road most roads are crowned making the left side of the road higher than the right side. A truck listing to port would tend to be more level going down the road. Also which way do these engines turn; do they torque the truck clockwise as seen from the drivers seat making the right starboard (right hand) side compress?
Old Jan 8, 2007 | 07:14 PM
Timmer's Avatar
it lists to the port cus the road crown lists to the starbard, thay do that so it rides level on the raod.
Old Jan 8, 2007 | 10:09 PM
larryt's Avatar
Check Springs
Originally Posted by derek.mckay
I don't know, maybe I just drink too much lol...but I am just ABOUT 100% positive that my truck lists slightly to the port side (leans to the left for all ya'll none Navy folks)...other people's trucks the same or should I head to the dealer?
Derek
I know on my 2wd the coil spring wire dia is different on the drivers side
I assume to take into account the driver & fuel weight.
My driverside wire is .915
My passenger wire is .895
There was a similar difference that I noticed on my hemi before I
traded up.
The part numbers are different (see tag on springs) from side to side.
I don't know if Dodge handled it similarly with the 4wd or not. Might be
worth checking.
larry
Old Jan 10, 2007 | 11:33 PM
plessm's Avatar
Do you have a dirt bike or something you could put in the right side of the bed to see if it levels out? Seems to me like 272 lbs of fuel could make it sit lower on the left.
I've got a 66 Mustang that sits 1/2" lower on the driver's side and it drives me crazy!!! I've replaced all suspension and measured everything and it's never been wrecked yet still can't figure out why it leans.
Doesn't the transfer case and front drive line sit mostly on the left side as well?
Old Jan 11, 2007 | 12:28 AM
BroncoHound's Avatar
on a chevy s10, it is a very common occurance. it is even called the "chevy lean" in the s10 circles. Belltech even came up with a spring spacer that is sold individually so you could raise the front driver's side 1/2" to level out with the passenger side. it had something to do with the design of the spring pocket on the driver's side as opposed to the passenger side. since your truck is leaning in the rear as well, i would think that most likely it is due to fuel weight and your body weight (you said you drive alone usually) sagging that side of the suspension over time. as was mentioned before, if your truck is still under warranty and you feel strongly about it, take it to the dealership and have them replace the coil and leafs.
moondog933
Introductions / New People
Oct 25, 2009 08:11 AM
jc67
Feb 6, 2008 08:02 PM
k_butz
Feb 23, 2007 03:42 PM
tobyw
15
Jan 6, 2005 06:06 AM
1stTimeAround
Oct 10, 2004 04:02 PM
