ez drain plug or finger touch
Old Nov 28, 2007 | 02:42 PM
skindaddy's Avatar
which one is better to buy?
from genos
Old Nov 28, 2007 | 05:13 PM
torquet's Avatar
I love my fumoto drain valve from Genos
Old Nov 28, 2007 | 05:15 PM
ptgarcia's Avatar
I use the easy drain. I do a lot of off roading and was afraid of kicking up a rock and breaking the fumoto.
Old Nov 28, 2007 | 08:00 PM
bry@n's Avatar
X2 . I love mine as well.
Old Nov 28, 2007 | 08:23 PM
RocketJohn's Avatar
a 3/8" torque wrench and you don't need either...
Old Nov 29, 2007 | 03:49 AM
Dodgezilla's Avatar
I have used both and like them equally as well. I have the Fumoto valve on my current truck...
Old Nov 29, 2007 | 06:26 AM
skindaddy's Avatar
do you wrap something around the fumoto to keep something or someone from opening it up
Old Nov 29, 2007 | 06:33 AM
bry@n's Avatar
No I don't. It actually has a little lip it sits in. You must clear the lip in order to open the valve. I had all these concerns when I bought mine, figured what the heck and went for it.
My thought process was, if indeed id did open, I would clearly be able to see the 3 gallons of oil on the ground.
I plow, take the truck into the woods and have never had a issue. The valve sits up pretty high and out of the way.
Old Nov 29, 2007 | 07:28 AM
skindaddy's Avatar
thanks brian
Old Jun 13, 2010 | 11:17 AM
Dave88LX's Avatar
Looks like Fumoto is the fingertip drain valve correct?
Old Jun 13, 2010 | 02:35 PM
Doj Dewd's Avatar
the fumoto is great, i have had it on my truck now for multiple oil changes with out any issues. makes the changes really easy. unless you literally go rock crawling - you should hae zero issues with ground clearance. once fully threaded in, it is quite strong and VERY well protected by the front axle/diff. i also have nothing on mine to keep it from opening. it requires action/force in two directions at once to open. i just threaded and re-threaded until the tab was pointing rearwards just for the peace of mind.
i had a friend install the ez drain (flush with green tube one) at the same time as me and it ended up costing him a lot of money. during one oil change the retainer and spring popped out of his valve and remained inside his oil pan out of fingers/tool reach via the tiny hole. it is brass so magnet didn't work either. ended up towing it to cummins and they had to remove the oil pan to get to it (requires hoisting the engine)!!!
Old Jun 13, 2010 | 02:46 PM
Danderson's Avatar
Yep. I put a small hose clamp to prevent the one in a million chance of the valve opening. Completely unnecessary,but that's just me. Collecting oil samples is much easier without the "deluge or nothing" drain factor of the stock plug.
Old Jun 13, 2010 | 09:36 PM
92'1stGen's Avatar
I like the Fumoto. I don't have it on the 06' yet, but I have it on the 92' and an 01' Excursion.
Old Jun 13, 2010 | 10:05 PM
.boB's Avatar
I have the Fumoto valve on the Cummins. The advantage is that you can drain the oil directly into old oil jugs, rather than into a bucket and then into the jugs. Yes, a torque wrench works. But this works better.
I'v been using these valves on various vehicles for many years. Never once had a failure.
Old Jun 13, 2010 | 10:36 PM
OldDodgeOwner's Avatar
I bought a Fumoto. It's been sitting on the shelf waiting for the next oil change to put it on. Only thing I'm wondering is the hole is awful small. How long does it take to drain completely?
