duramax wheels fit dodge? kmc hoss
I found a great deal on the hoss kmc wheel in a 20" from a duramax. My question is will they fit my 07 mega cab? And also the offest of the kmc hoss will it allow for a 35"? Thanks.
The wheels are available in different offsets likely, but the stock GM wheels have more neg offset than Dodge wheels, so if they're GM specific they might not be offset out as much as a Dodge specific wheel. I'd get the exact part # off of them and call KMC to make sure they'll work without rubbing on the inside.
The stock Dodge wheels are lug centric and don't bear on the hub, where the stock GM wheels are hub centric. ie: Dodge wheels will fit on a GM truck, but the center hole is too small on GM trucks to fit on a Dodge without milling out the hole. Check out the center hole dia too. Lug pattern is the same between the 2.
ya thats what I was thinking, only problem is idk if the guy can find the exact part number. Was hopeing for maybe that someone would know exactly if this particular wheel would work on both trucks or something along those lines, i guess ill call kmc.
Lomarker
Nov 5, 2008 02:34 AM
smokinram99
May 31, 2008 08:27 AM
CDoskocil9
Jun 16, 2007 08:48 PM
Joe T
Jun 14, 2007 01:34 AM
checkster
Mar 7, 2007 12:14 PM
